  4. Premium gas prices
Premium gas prices
41 Posts 19 Posters 2.9k Views
    Schwanger
    E85 is actually 113 octane and $1.44/gallon. If you want to run E85 you need to use alcohol safe fuel line and retune for it being that you need to burn more of it.
      http://autos.msn.com/everyday/gasstations.aspx?zip=58103&src=QL
      • dubbsyD Offline
        dubbsyD Offline
        ichibankilla wrote:
        It's basically a proven fact that there is very little if any difference between 87,89,91 and 92 octane performance wise.
        in a stock car, probably not. but hell, even my nearly stock ass 94 Thunderbird will detonate if I run 87 - needless to say I don't run 87 anymore. (only thing different is it was dyno tuned)
          So what's the highest octane my 4 banger can run? It has the usual aftermarket stuff. Intake, header, exhaust, ignition. No internal work.
          • sleepermaximaS Offline
            sleepermaxima
            PSiedTSi wrote:
            well when your running boost on an N/A motor im pretty sure regular gas is not an option!
            on a sidenote...sleepermaxima bradys in moorhead on 8th street has 100octane unleaded in the pump if you can run that...?
            sonofa! I called that store and the lady that I talked to said that they only had leaded race fuel... nothing unleaded. This was a couple months ago and maybe things have changed over there since then. Oh well.
            Thanks for the info.
            Do you know how much they are charging for it? I can mix pump with the 104 at about 1:1 to give about 98 octane (which is perfect for that pig). The price for that is about 3.75 after I average the prices per gallon.
            2003 Honda VTX 1800 C
              sleepermaxima
              Interesting... BTW, Where are you getting this info? I've been meaning to research this but I have not found anything more than what I read from second-hand sources (like from forums like this). I would like to have a solid basis before I start retooling my setup.
                Schwanger
                I've been doing a little research for the next NDSU formula SAE car. I think there is some information about it on the North Dakota Corn Growers Association website. But all you need is new fuel line (I think steel braided is alcohol resistant) and then a new fuel map and you're ready to go.
                  solem22
                  in GF we have 100 or 110 for $3.95 a gallon. IMO its not a bad price, considering i am only getting 3 gallons at a time.
                  We dont need your happy endings.
                    i am not sure what it is priced at right now...
                    • RaiderR Offline
                      RaiderR Offline
                      Raider
                      http://www.agriculture.state.ia.us/e85q&a.html
                      POWERD BY
                      • dubbsyD Offline
                        dubbsyD Offline
                        it's not how high of octane you can run, it's how low. you're not going to see performance gains running 93 in a car that runs fine on 87 (or anything worth noticing) - so if it doesn't detonate, use it. too high of octane, I believe it won't burn it fully (It hink that was result), too low of octane will leave your motor in the street.
                          While this is true, some race fuels are oxygenated and therefore can actually add slight power increases while still preventing detonation.
                            toxshox
                            e-85 scares me :eek:
                              so if I heard this right e-85 burns a little hotter, has higher octane, and all I'd have to do is retune my carb?
                                You might have to rejet your carb. Definately wanna make sure your fuel lines/pump/anything else rubber or plastic in the fuel system are ready for E85 as well.
                                  i brought up this E85 idea way back last year...but i got shut down about it...now it's as if ppl wanna actually try to see what exactly needs to be done...i know that everything in the fuel system if not corrosion resistant needs to be replaced. you will need (i believe) bigger injectors for a fi'd car because e85 burns quicker then reg. gas so you will use more. i'm seriously looking into e85 for the slo when i swap the motor...i figure it'll already be all apart, and im getting a vafc, so why not just go that little extra step and pay up another 300ish so i can run 105+ octane for less than $1.60 a gallon...that makes sense to me, expecially in the long run...because the way i figure it, the difference in gas milage doesnt nearly outway the difference in cost and difference in performance one can get from the higher octane. my .02
                                    you wont gain performance by switching to higher octane alone...thats why you run as little octane as possible...and you drive a honda why are you worried about fuel prices in the first place?
                                      I drive a mustang, don't know if you were referring to me or not, Tsi. I get 14-16 mpg. With only larger injectors I can run it? What about the rubber hose around an inline fuel filter? What about the filter itself? Are they in danger of corrosion?
                                        no sorry i was talking to torbs....
                                        • assasainA Offline
                                          assasainA Offline
                                          assasain
                                          ill check it out when im home again on the 10th ish
