  4. Premium gas prices
Premium gas prices
41 Posts 19 Posters 3.0k Views
    so if I heard this right e-85 burns a little hotter, has higher octane, and all I'd have to do is retune my carb?
      You might have to rejet your carb. Definately wanna make sure your fuel lines/pump/anything else rubber or plastic in the fuel system are ready for E85 as well.
      • torbsT
        torbsT
        i brought up this E85 idea way back last year...but i got shut down about it...now it's as if ppl wanna actually try to see what exactly needs to be done...i know that everything in the fuel system if not corrosion resistant needs to be replaced. you will need (i believe) bigger injectors for a fi'd car because e85 burns quicker then reg. gas so you will use more. i'm seriously looking into e85 for the slo when i swap the motor...i figure it'll already be all apart, and im getting a vafc, so why not just go that little extra step and pay up another 300ish so i can run 105+ octane for less than $1.60 a gallon...that makes sense to me, expecially in the long run...because the way i figure it, the difference in gas milage doesnt nearly outway the difference in cost and difference in performance one can get from the higher octane. my .02
        • PSiedTSiP
          PSiedTSiP
          you wont gain performance by switching to higher octane alone...thats why you run as little octane as possible...and you drive a honda why are you worried about fuel prices in the first place?
          spanish-rice;237125 wrote:
            I drive a mustang, don't know if you were referring to me or not, Tsi. I get 14-16 mpg. With only larger injectors I can run it? What about the rubber hose around an inline fuel filter? What about the filter itself? Are they in danger of corrosion?
            • PSiedTSiP
              PSiedTSiP
              no sorry i was talking to torbs....
              • assasainA
                assasainA
                assasain
                ill check it out when im home again on the 10th ish
                • O
                  O
                  you people all need to do a lot of research before you even think about putting e85 into your cars.
                  first- if you would google for "e85 blend," you would see that ethanol is about 113 octane and e85 is about 110. or i could save you the time:
                  http://www.hannity.com/forum/archive/index.php/t-14622.html <~~ find octane on the page
                  second - have you ever looked at drag cars that burn alcohol? how big are the injectors? 1000-2000cc/min is not uncommon, because alcohol has much less energy than gasoline.
                  third - kiss all the rubber and aluminum in your fuel system goodbye, because alcohol will eat it over time. it's recommended to not use more than 30% alcohol in normal gasoline engines, but you would need more gasoline (as opposed to less with higher octane gasoline).
                  fourth - because of it having less energy per unit, mileage would decrease relative to what percentage alcohol is in the system... so the final fuel cost to travel x miles would be almost the same. however, because of all the modifications necessary to run it safely... e85 would cost more with a normal car.
                  i've tried, it works, but not as well as 92 or 93 octane. don't use it.
                  and for the rest of you children spouting off about something that you don't know anything about... perhaps you should do a little research before spreading false facts?
                  • McAdamM
                    McAdamM
                    McAdam
                    Out There, a lot of what you said is completely true. Somehow people have the micsonception that you can just run E85 on any old motor.... NOT even close to true.
                    If one were to build a motor to run off of E85 specifically (somewhere in the neighborhood of 13 or 14:1 compression, tuned accordingly with a standalone) you could get some serious HP and not too shabby mileage out of it.
                    Now, Ive been looking into it just from a fun standpoint. Considering building a high compression(11:1) low boost(7 or 8psi) combo. I think you could have a lot of fun with that. Another bad idea would be to make an overly complicated turbo header with a jake brake type SWING valve to switch between routing the exhaust to the turbo (E85), or just straight to the exhaust (gasoline) and running it on MegaSquirt & Spark Extra with 2 different VE tables and just switch them depending on whats in my tank or if Im at the track or not.
                    McAdam
                    • torbsT
                      torbsT
                      me personally, id build a motor/fuel system that would be able to handle e85...also, i think 1000hp with 1000-2000cc of fuel isnt bad...remember, drag cars are designed to eat up fuel and make 1000hp/cyl on average...trust me, ive been researching this idea for months, so im not a total idiot on the subject...
                      • torbsT
                        torbsT
                        and tony, i know a stock honduh wouldnt benifit, but a built one just may hehe
                        • 7ormore7
                          7ormore7
                          7ormore
                          Alright to so i read this all but i still want to know were i can get some 95 octain fuel, or greater, i'm running two 550cc inj and two 680cc with an safc and its got a turbo.
                          Thanks
                            It cost $2.94 here for Premo.
                            • dubbsyD
                              dubbsyD
                              yep, time to sell both the cars and find something efficient.
                              15mpg in the explorer and premium (granted I can get 20+) in the Tbird....
                              ack.
                              I remember....
                              when gas was $0.87
                              • O
                                O
                                dubbsy wrote:
                                I remember....
                                when gas was $0.87
                                • dubbsyD
                                  dubbsyD
                                  out there wrote:
                                  shit, I'm actually thinking I remember it being $0.64 for a very short period of time... (like a day or two)
                                  and I"m not that fucking old! (21)
                                  I told myself a couple years ago I was giving up cars and taking up stamp collecting.
                                  I think now is the time to go through with that.
                                    I too remember when it was under a buck a gallon. I think the new thing is going to be modding out Hydrogen powered cars.
