New to Fargo Argument
Ok, now that we've both agreed that the USDM EJ20 will break unless you sleeve it or swap it to the EJ22 we're fine. The way you worded it before sounded like you can take an EJ20 and bolt on a big turbo and supporting mods and get to 500 WHP. Swapping in an EJ22 is always the best route for huge power in a subaru, friggen motor is awesome and can handle insane amounts of boost.
To address the points that I think need addressing:
C. Disagree with you there. I've owned both and Honda parts are definately cheaper. The gap has closed a little though, not quite as bad as it was a couple years ago.
D. I change my tires and would change my suspension settings from Auto-x to Drags as well.
E. Thanks for the links. But those were not attained from an inertia dyno. Not trying to nit pick here and not taking away from any of those cars, but the same car on an inertia dyno would most likely not produce that high of numbers.
toxshox wrote:
not for a wrx...take a look at www.cobbtuning.comStage 2
Package Includes: AccessPORT
COBB Turbo-Back Exhaust System
i have a wrx....
BTW I don't auto-x just due to the size of the turbo. I could if I wanted though.
It'd just be a burnout machine. -
tjamz wrote:
ok, for some reason I thought that I heard you have done so in the past...like a couple turbos ago...anyway, thanks for clarifying
chuck your an asshole quit picking on toxshoxlol jk
I auto-x'd my old DSM. Fuckin tank.
I had em both at the same time. It was fun but I sold it for way too much money.
My DSM locked an xfer case up about 90 miles from here south on the way to Sioux Falls, and went skidding @ 80 mph w/ all 4 wheels locked up.
