  4. Question for a Plumber or construction worker...
20 Posts 10 Posters 870 Views
  • lord_deastofactL Offline
    lord_deastofact
    ok the tub went in so it will come out, needless to say, just to figure out how they brought it in. No doubt the door wasn't in yet, so you might wanna consider that. Also yes most older tubs are very heavy so get a few strong guys to help you move it, about 4 people would make it very managable to move around as need be. Also if you are still looking at cutting it in half a sawzall prolly won't have the bite to get through the finish on the tub, but I would suggest getting a better blade if you still want to use that otherwise, get a small hand grinder and go out and buy a cutting disk for it. prolly a couple of them, they are alittle spendy, up to 5 or more dollars a disk, but on the construction site I've yet to find something a cutting disk can't get through. we just don't use them as much as that they can get spendy if you use up 100 of them in a day. other then that I can't think of anything else, I've taken a few tubs out and they were only trouble when breaking them away from where they had been setting for years. hopefully this helps and good luck!
    Minute ricer!
    • DanglerD Offline
      DanglerD Offline
      Dangler
      Thanks for the feedback guys.
      It is cast iron and I did chip away the finish down to the cast iron first. New sawsall blades didn't go through it.
      The "depth of the tub" from the floor to the top of it is 18". The width of the door is like 25" so, if it can be lifted up, tipped on its side, it can be pulled out the door.
      It is completely disconnected - i can move it around when I get a hammer or pry bar under it.
      I don't have a small hand grinder - I'll pay good money to get this thing out - what's it worth????
      I need 3 more guys to help me pull it out. I can work on it tonight after 6:00. I would bet we could have it out in 2 hours at the most. Does $20 an hour per person plus beer sound fair????
        lord_deastofact
        if you want help I have class till 6pm, but would be willing to try to make it over there to give ya a hand, pm me
        Minute ricer!
          damn if i wasnt going to mpls i would definately lend a hand...
            A electric die grinder with a cutoff wheel should be able to cut that biotch in half.
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              Just get "little" Smith, myself, and you...should be able to handle it;) Let me know if you need help still, I can come over later on tonight.
              • DanglerD Offline
                DanglerD Offline
                Dangler
                Got if figured out, thanks!
                • DanglerD Offline
                  DanglerD Offline
                  Dangler
                  306-7877 is my cell
                  • DanglerD Offline
                    DanglerD Offline
                    Dangler
                    No need to swing by tonight
                    It started to break apart - just needed a bigger hammer, right Jeff 😉
                    8lb sledge hammer and it started to come apart. Thanks for the advice guys.
                    Anyone a plumber who wants to make some $$ on the side putting in the new tub?
                    Later
                    Brett
                    • camzaro28C Offline
                      camzaro28C Offline
                      camzaro28
                      if u plan on puttin some tile in , let me knwo. i would be glad to do it for you.
                      about the plumber, ill go back to work and see who my boss uses for all our jobs. around 5 ill post the number if u havent found someone already
                      jig 4 prez
                      • RE-EnemaR Offline
                        RE-EnemaR Offline
                        RE-Enema
                        When in doubt use a BFH. 😄
                          lord_deastofact
                          good to hear! "if brute force doesn't work, your not usign enough!"
                          Minute ricer!
                            sorry to chime in late....but...you should have simply removed the door or busted off the legs to get it out. There are a few places in the area who pay rather well for a "complete" cast iron tub. If nothing else though fargo iron and metal will give you fifty bucks for the pieces..
                              believe it or not, thats my motto 🙂
