  4. Game On!!
Game On!!
69 Posts 25 Posters 3.6k Views
    Well plans changed going bigger.
    Relocating the ECU to where the battery used to be so i can run a sheetmetal intake manifold, 75mm TB, elimintating the drive by wire and going to a full stand alone. We started moving the ECU last night, 92 fricken wires extended 10 ft. 42 done, 50 to go then all to hack it back apart to wire in the Haltech.
    Shooting for 500whp on 15 psi for now. Prolly gonna do a TT bottom end swap this winter, then who knows.
    Nick
    SLS
    • RaiderR Offline
      RaiderR Offline
      Raider
      holy crap that doesnt look like fun at all
      POWERD BY
        why did you decide to go haltech instead of AEM etc? just curious
        also, is that gonna affect the sensors/ecu at all extending the wires? I know its not a whole lot but sometimes that stuff is very sensitive to resistance...
          what advantages does the supra block offer? they're both the same bore and stroke... different materials in the crank, block or something that isn't readily noticeable?
            Better hope your wiring works on that thing!
            • F Offline
              F Offline
              Fitzy
              Oh, it will! 🙂
              2002 Honda S2000
              2006 Dodge Ram CTD
                the is300 has weaker rods.
                  IS 300 is 10.5:1, and the rods are a lot weaker. Stock IS300 rods will only take about 500-550 before their done. I plan to push that limit if it gies it goes but i think i'll be alright.
                  I think we'll be ok on the wiring i double and triple checked everytime we wired one, haha!!
                  Nick
                  • harwood39H Offline
                    harwood39H Offline
                    harwood39
                    Wow. And i thaught my 22 wires i had to redo was a pain in the ass. I would hate to do that, and i noticed you just used plain yelloy wire, didnt even color code it at all, what a pain that would be.
                    2730 5th Ave S. Unit C
                    Fargo, ND 58103
                    701-429-3686
                      Last time i checked you cant get factory colored wiring in spools, and even if you could i wouldn't wanna buy 92 spools thats why you label each wire....
                        98+ 2JZ's with VVTi have weaker rods i believe right?
                          would you be looking for a stock or built block? wouldn't it be better to just rebuild the is block with your choice of rods, pistons, etc? that way you KNOW it's good for what you'll be throwing at it
                            what's the point... there are many stock supra blocks that make 1000hp or close to it
                              That is way cool. There are a couple low 10 second civics down here. They are just scary fast.
                              One goes by the screen name "stangslayer" and he does this over and over.
                              Another has a plate that reads "urv8scks"
                              His car is so loud under accel that I can't hear for a while after he leaves porkies (drive in we hang out at in st paul)
                              Honestly they have the right to poke fun, it is amazing to see these cars making these power levels.
                              Good luck, looks cool as hell!!!!!
                                now i know. i suppose i should have written a disclaimer first?
                                  Do you always have to question EVERYTHING i do like i dont have a means behind doing it??
                                  • drift86D Offline
                                    drift86D Offline
                                    drift86
                                    way to go nick looks good hope to see it out soon
                                    AE86 project: sold
                                    93 r33 gts25t new project
                                    00 impreza obs
                                      slowvo
                                      So why do we never see these guys at rock falls?
                                      Oh, and "urv8scks" i hear only ran a 12, but that was on low boost.
                                      there probably quick...but 10's?? i wanna see this shit
                                        curiosity a good enough reason?
                                          Al the fabrication completed and all the wires ran. Threw it together for the show but im gonna rip it all back apart and anodize everything blue.
