Mega Squirt
My take on it, is its not needed on a 1G DSM. All you need on a 1G DSM is to eliminate the MAS and your well on your way to 600hp capable. The ease of using a VPC/S-AFC combo is just hard to pass by. Install it and have it running flawlessly the same day. The stock DSM ECU does a pretty good job w/ timing aQ it sits. Only gain w/ the Megasquirt is the datalogging capabilities but then you gotta invest in a lap top as well and all y-ur gonna really log is knock counts anyways and on race gas you shouldn't really ever see any kock anyways. If i were to do aother DSM for a basic 500-600hp setup i'd go right back to the VPC/S-AFC combo, tune on a wideband and toss out the knock sensor.
But to each there one, do hat you want, im just saying what i'd do for the setup/power your looking to make. If your looking to make 600+ then i'd go right to an AEM otherwise i wouldn't even bother w/ more than VPC/AC.
how about for other applications, such as non DSM?
the whole megasquirt thing is an excellent way to keep your engine running. My friend with the 280Z and the megasquirt is getting ready to megasquirt an 83 280zx turbo, with the ignition control. that should be interesting to see.
On the "you get what you pay for" note..... the reason megasquirt is so cheap is because of the software. Its freeware. the system itself is capable of AT LEAST as much as SDS, for about 1/5th the price, and thats for the prebuilt unit. Also, they just released some PDA software that allows you to run the damn thing on that!
Megasquirt is, in my opinion, better than any piggyback. You can get one with a 3 bar map sensor, so hi boost situations arent a problem. You can also get 12x12 VE and ignition tables in a code download called "Megasquirt and Spark Extra" plus, megasquirt II is now out. And that has a freaking FAST processor.
I myself am waiting for Megasquirt Ultra. It will have 12 user definable outputs, so on my I6 motor, that means 6 injectors and 3 for ignition. Full sequential Fuel injection as welll as 3 wasted spark coil packs. Im sure I can find a use for the other 3 outputs as well.
McAdam
When watching the 1011rwhp Parrish video something besides the insane amount of power sparked my attention.
Parrish video thread:
http://www.fargostreet.com/showthread.php?t=3981If you look closely at the video you can see that this truck is running Megasquirt engine mangagement. See the attached when shows a screenshot of the video.
Look at the A/F curve at 3:26 and you will see that it is very flat all the way across the rev range. Put in the hands of the right people, Megasquirt is a completely capable engine management system.
Lucas
PSI2HI wrote:
You can make a completlt flat A/F curve w/ any managment, even piggybacks and chips, so whats your point there?I simply wanted to show that this system is being used on applications that have made tremendous power. I'm pretty sure Parrish could afford to run any standalone EMS, but chose to run a Megasquirt for whatever reason and it has served his 1000+ HP needs.
A few of the LS1 guys who need a system capable of driving low impedance injectors have used Megasquirt with good results. With the alternative being a $2500+ BS3, it's a pretty good buy.
I'd like to see a Megasquirt system in person, though. What's the ETA on your project car?
adog wrote:
A few of the LS1 guys who need a system capable of driving low impedance injectors have used Megasquirt with good results. With the alternative being a $2500+ BS3, it's a pretty good buy.I'd like to see a Megasquirt system in person, though. What's the ETA on your project car?
I should have MS running on my car within a few weeks. I will update this thread when it happens. I have to get off my lazy ass and put the engine back together first..
