  4. New Car
New Car
20 Posts 10 Posters 783 Views
    nice ride, are they 17's on it. what else id done to it??
    • hondaking424H Offline
      hondaking424
      hey thanks man yeah they are 17's wrapped in Marshal matrac tx tires, i have a'pexi exhaust, and AEM short ram intake right now im am buying some new headers, ignition wires, and a new cam gears after i get paid next week.
      • FlowcusF Offline
        FlowcusF Offline
        Flowcus
        Dont buy headers unless they are Race headers... shorty headers make barely any difference.
        If you can find an SVT header... they are a really good header for the focus and you can keep the cat if you want.
        I ride random bitches.
          hondaking424
          hey thanks for the tip, im not allowed to have a high flow cat because i guess there highly illegale if you dont have 50,000 or more miles on your car for some reason.
          • FlowcusF Offline
            FlowcusF Offline
            Flowcus
            Race headers elimintate the cat completely... so yeah their very illegal. But with shorty headers you barely see any gains.
            Shit id just buy a used turbo kit from one of the MANY focus websites out there. You can find an Aero charger kit for $1200-$1500 but problem is any shaft play and its hard to get rebuild kits for them. Also they are self contained turbos meaning no oil feed or return lines. So you have to buy oil for them and check them on a regular basis otherwise youll burn it up fast.
            Check out these forums for more help. They are the best ones I have found to date, and there is always some good parts for sale cheap on the classifieds.
            www.focaljet.com
            www.focusfanatics.com
              I will now seriously consider a Focus as a vehicle.
                hondaking424
                thanks for the sites, and i was also wondering if a zetec works the same as a vtec i dont know much about these ford motors yet but im workin on it.
                  They are based on the same idea but go about it differently. I think I maybe wrong.
                    i've never heard that before, go try to get one put on and see what happenes.
                      As far as the cat being illegal, it would be way more legal than any custom exhaust in the F-M area.
                      • camzaro28C Offline
                        camzaro28C Offline
                        camzaro28
                        u live in ND? if so it doesnt really matter if its illegal or not.
                        jig 4 prez
                        • FlowcusF Offline
                          FlowcusF Offline
                          Flowcus
                          Mine is for sale... its an SVT loaded if your interested ill get you more info and pictures.
                          Also as far as Zetec and Vtec... the Zetec on my car is intake side only and it just adjusts the timing on the cam to allow more air in and also adds more fuel. It doesnt kick in until 5krpm, and at the same time a 2nd runner in the intake manifold opens up.
                          • TsiTomT Offline
                            TsiTomT Offline
                            TsiTom
                            Most random exhaust shops will not, in any way, help you eliminate your cat. At any rate...a high flow cat (or no cat) is a STUPID idea unless you have some kind of forced induction or higher compression engine... You'll actually be losing power more than gaining it.
                            Tom Opgrand
                            2011 Camry
                              maybe not losing it but shifting the powerband a little higher and hurting your low end...if you have a 5spd it doesnt really affect you that much....a high flow cat doesnt really hurt that much cause its still restrictive as hell...
                              • FlowcusF Offline
                                FlowcusF Offline
                                Flowcus
                                Actually if I were to get an off road pipe for my car it would help it... more low end power and its dyno proven 9whp 6wtq. So thats not always true... although my focus is 10:2:1 compression which is considerably bigger then his. Also mine uses fuel like a turbo car... which pisses me off.
                                  modifying ANY part of the car that could affect emissions is illegal. if you're going to build your car for performance and keep your tail between your legs... buy a hybrid and forget performance, because the stuff that nets the best gains is going to require illegal modifications to see/feel those gains
                                  • StormwalkerS Offline
                                    Stormwalker
                                    I have heard that there is only 2 reasons you would be allowed to change your catalytic converter.
                                    1)The current piece is in excess of 50,000 miles of use
                                    2)The current piece is damaged beyond repair
                                    So please, please, be careful around your cat, especially if you want to replace it with a higher flowing unit. Try not to accidentally drive a screwdriver or drill through it several times, or miss with a sawzall and saw it in half. Because if that happened, you would have to replace it.
                                    www.tcstangs.com
                                    • krzydrftr93K Offline
                                      krzydrftr93
                                      Not bad looking at all. Looking good. Got anything under the hood?
                                      Matt
                                      92 Civic HB
                                      JDM d15b w/14b@8psi
                                        hondaking424
                                        i will get picks of the exhaust and the AEM short ram tommarow
