  3. ICE and Detailing
  4. How do i get this shit off my windows!!!!!
13 Posts 7 Posters 1.8k Views
    hmm...try a little vinegar and water
    • harwood39H Offline
      harwood39H Offline
      harwood39
      im goin to try simple green also, some people said to try that
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        goo gone, brake cleaner, carb cleaner, jsut watch your paint, I'd advise applying to a rag and wiping.
        • krzydrftr93K Offline
          krzydrftr93
          paint thinner but like CCr said put it on a rag then scrub. If it comes off. then clean the windows with some kind of window cleaner. I work at in recon at tri state. they have some crazy shit to use. The degreaser we use to wash stains the windows and thinner takes that off or else some kind of bug and tar should work to.
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
          • 94NDTA9 Offline
            94NDTA9 Offline
            DO NOT use simple green on your paint.
            Try some 3M citrus based adhesive remover.
            • darkelvisD Offline
              darkelvisD Offline
              darkelvis
              P.S. it is aphid (sp) shit. Not bug spray. 🙂
                harwood39H Offline
                harwood39
                oh, its actually eched into my glass, it wont come off with anything. And i wasnt using it on the paint. ITS ON THE WINDOWS. It cleaned up alot with buffing compound in a small test area.
                Fargo, ND 58103
                701-429-3686
                • 94NDTA9 Offline
                  94NDTA9 Offline
                  My bad.
                  if it is TRUELLY etched into your glass you should try buffing it out, if not, 3m Citrus adhesive remover
                    harwood39H Offline
                    harwood39
                    im buffing it out after school. Im thinking of eventually getting a new windsheild tho, i found so many rock chips in it and it leaks at the top a little.
                    Fargo, ND 58103
                    701-429-3686
                      A sledge hammer and a chisel will take it right out. You won't even be able to tell the windows there. 😄
                        harwood39H Offline
                        harwood39
                        got it off, razor blades are the shit.
                        Fargo, ND 58103
                        701-429-3686
                          aliengotpsi
                          i saw just going to add use a SS razor blade with glass cleaner... or take the car to me....
                          Kevin Smith
                          Straightlinedetailing.com
