  3. ICE and Detailing
  4. How do i get this shit off my windows!!!!!
13 Posts 7 Posters 1.8k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    im goin to try simple green also, some people said to try that
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      goo gone, brake cleaner, carb cleaner, jsut watch your paint, I'd advise applying to a rag and wiping.
      • krzydrftr93K Offline
        krzydrftr93
        paint thinner but like CCr said put it on a rag then scrub. If it comes off. then clean the windows with some kind of window cleaner. I work at in recon at tri state. they have some crazy shit to use. The degreaser we use to wash stains the windows and thinner takes that off or else some kind of bug and tar should work to.
        Matt
        92 Civic HB
        JDM d15b w/14b@8psi
        • 94NDTA9 Offline
          94NDTA9 Offline
          DO NOT use simple green on your paint.
          Try some 3M citrus based adhesive remover.
          • darkelvisD Offline
            darkelvisD Offline
            darkelvis
            P.S. it is aphid (sp) shit. Not bug spray. 🙂
              harwood39H Offline
              harwood39
              oh, its actually eched into my glass, it wont come off with anything. And i wasnt using it on the paint. ITS ON THE WINDOWS. It cleaned up alot with buffing compound in a small test area.
              Fargo, ND 58103
              701-429-3686
              • 94NDTA9 Offline
                94NDTA9 Offline
                My bad.
                if it is TRUELLY etched into your glass you should try buffing it out, if not, 3m Citrus adhesive remover
                  harwood39H Offline
                  harwood39
                  im buffing it out after school. Im thinking of eventually getting a new windsheild tho, i found so many rock chips in it and it leaks at the top a little.
                  Fargo, ND 58103
                  701-429-3686
                    A sledge hammer and a chisel will take it right out. You won't even be able to tell the windows there. 😄
                      harwood39H Offline
                      harwood39
                      got it off, razor blades are the shit.
                      Fargo, ND 58103
                      701-429-3686
                        aliengotpsi
                        i saw just going to add use a SS razor blade with glass cleaner... or take the car to me....
                        Kevin Smith
                        Straightlinedetailing.com
