  4. Turbo guys plz help
Turbo guys plz help
22 Posts 10 Posters 1.0k Views
  • RaiderR Offline
    RaiderR Offline
    Raider
    ok what kind of #'s would these turbo's produce...I dont know shit about turbo's
    2x Precision
    GT35 TO476 S cover .58ar
    a guy is building a 32v 5.4l with 2 of these on there
    POWERD BY
      Depends on the boost level. Typically that turbo on a 4cyl makes in the 500-600hp range.
        a lot!
        • RaiderR Offline
          RaiderR Offline
          Raider
          so maybe 800-1000 hp then?
          POWERD BY
            I am guessing quite a bit. Let's just put it this way, more than stock.
            GT35R = my next turbo if I keep the Talon.
              More details would be nice. Like how much boost does he plan on running, etc.. Definatly more than capable of 800-1000whp. Being its a v-band turbine side they are T4's but he went to a pretty small exhaust housing. Built motor, stock motor?
              • RaiderR Offline
                RaiderR Offline
                Raider
                20psi with 8:1 comp...the 32v is built tough from whatI read
                POWERD BY
                • RaiderR Offline
                  RaiderR Offline
                  Raider
                  so with this setup will it be a quick spool up?
                  POWERD BY
                    Should spool really quick w/ those little exhaust housing and 2.7L/turbo.
                    I got an idea, how about you build one and lets find out how much power it will make :-).
                    • RaiderR Offline
                      RaiderR Offline
                      Raider
                      Im looking at doing a turbo setup...not sure if I would do a single or a twin...I have seen #'s of 400-600rwhp with a t67 and up to 800rwhp with a T76 and now this guy is doing a 32v twin kit...there is a kit already out on the market for 5799.99...Im not sure if thats a good buy when it comes to turbo kits
                      POWERD BY
                        Well you're talking to the man about turbo kits.
                          completely off topic.. but thats fucking sexy lookin'.
                            i'll i got to say is you better post dyno sheet and video's when available
                            • 91nbtsi9 Offline
                              91nbtsi9 Offline
                              Go single. Cheaper and much more simple. What engine do you have?
                              • RaiderR Offline
                                RaiderR Offline
                                Raider
                                5.4l
                                POWERD BY
                                • 91nbtsi9 Offline
                                  91nbtsi9 Offline
                                  And what would your goals be for power wise?
                                  • RaiderR Offline
                                    RaiderR Offline
                                    Raider
                                    well on the t67 kit that is already built for 5500.00 they are getting 423rwhp on a stock block...I would be happy with 500
                                    POWERD BY
                                      you could get 500hp down much cheaper then six grand if you went single..
                                      • theobliviousT Offline
                                        theoblivious
                                        full-race kit with a gt turbo and everythign you need except ems is 5500 if that gives you any sort of clue.
                                        BOOST....to be continued
                                        • RaiderR Offline
                                          RaiderR Offline
                                          Raider
                                          the single T67 kit is out right now for 5500.00
                                          POWERD BY
