EVO 8 Mas on a 1g?
I was doing some reading on dsmtuners and there was a thread started about installing an evo mas in a 1g. The 2g mas and evo mas have the same number of prongs but a different sized connector....and people using dsmlink have apparently done it.
Basically im curious to know if it is at all possible? The evo mas flows close to 30% more than the 2g and is comparable to a GM maf....So you can see why im really interested in this...
so buy one and test it out....get a datalogger and see what it throws out.
do you think you outflow a 2g with your current setup? or are you just curious..
that mas is set up for 550's and you will not over run a 1g mas till 350-370 and a 2g mas will over run at 450-470max till you get a 60 trim keep the 1g mas
my .02
