  4. 96 nissan 200 sx w/sr 20 det not installed
30 Posts 10 Posters 1.5k Views
  • civtegraC Offline
    civtegraC Offline
    civtegra
    idk ill check with him. i think his phone got disconnected so ill check after work n ill get back to u
    • nissan_squirrel_MIRN Offline
      nissan_squirrel_MIR
      yea ummm. .. the engine for the car is the GTiR SR20DET.
      " And Let Their Blood Fall From My Hands."
        have you seen the car or anything?^^^ isnt the GTiR motor better?
        • civtegraC Offline
          civtegraC Offline
          civtegra
          yeah ive seen the car but the swap isnt put in or n e thing. n i do beleave the gtir is better but i know nothin about it his phone just got connected agian his # is 218 234 7461
            nissan_squirrel_MIR
            the GTiR motor is a good engine . . . the only thing that you go with the better is when it comes to black tops and red tops this engine is a red top. . . and no i haven't seen it but me and scott talked for about two hours about the car and stuff. . But i do believe that the GTiR engine has 225-230hp J-Spec . . But don't quote me on that
              yeah i did a little reading up on it last night...it sounds like a pretty straight forward swap with like 5 changes in wires and thats about it....the only thing you have to do is use a JWT ecu and theres only like 1 or 2 companys that make parts for the GTiR motor...but it does have ITBs 🙂
              • civtegraC Offline
                civtegraC Offline
                civtegra
                c u guys know more about this than i do
                  there is another tuning company that does the stuff but mostly for ka's i do believe they do some sr stuff. why can't you use the ecu that came with the motor or wasn't there one like he just got a motor and is using stock stuff in car?
                    cause the harness in the car plugs into the GTiR motor...so you just use that ECU...idk thats what people just said...
                    • harwood39H Offline
                      harwood39H Offline
                      harwood39
                      so is this jsut the motor and tranny or a complete swap that comes with the car?
                      2730 5th Ave S. Unit C
                      Fargo, ND 58103
                      701-429-3686
                        so there isn't a stock gtir ecu inculded
                        also arent most of JWT ecu's programed for otherstuff done to the motor. like z32maf, injectors, cams, ect.
                          nope its programmed for the swap...the GTiR motor comes complete but why use the GTiR ecu when you use the stock harness? you have to swap the whole harness then and im not sure it works...
                            nissan_squirrel_MIR
                            you need to use the special programmed JWT ECU because of all the tuning that needs to be done for it. . the ECU keeps into consideration what is actually in the car. and whom ever it was that asked. its a GTiR engine with tranny but the tranny is an AWD tranny . . .
