  4. Gauges
Gauges
8 Posts 5 Posters 814 Views
  • Big-DB Offline
    Big-DB Offline
    Big-D
    when hooking up gauges like an oil pressure or water temp gauge to you actually have to ground it by the sending unit or not?
    • harwood39H Offline
      harwood39H Offline
      harwood39
      no
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
      • Big-DB Offline
        Big-DB Offline
        Big-D
        cool
          if you ground it in the wrong spot, you could notice funny things happen. Current goes through that part or the car with another circuit, it might light up when you use something like the horn or winshield wipers. Ground it somewhere, then check your horn, windshield wipers, headlights, etc. If it flashes the backlight of the gauges or something like that, ground it somewhere else. just a quick tip.
          • Big-DB Offline
            Big-DB Offline
            Big-D
            yea weirdnshit has happened like the water temp gauge that poped off he top of it like where you hook up the wire....and the gauge only worked yesterday for like 10 min.... and then i just pounded the top back in and it still doesnt work and i think its grounded right because i grounded the gauge with the ground on the light for the gauge....and the lights still light up.
            • TsiTomT Offline
              TsiTomT Offline
              TsiTom
              That is the longest run-on sentance ive seen yet.
              make sure your ground wires are tightened down really good....other than that good luck.
              Tom Opgrand
              2011 Camry
                use an empty spot in the fuse block instead of splicing it into the stearing colum wires ect... .... .. . JOEL!
                • Big-DB Offline
                  Big-DB Offline
                  Big-D
                  I did that, like i tied the lights into the headlight fuse, and the one that powers the gauge needs to be on something that is switched so i tied that one into the power window fuse because that is one of very few that one powers when you turn the car on, or to accesory.
