  4. slow gs
slow gs
14 Posts 7 Posters 1.2k Views
  • J Offline
    J Offline
    Jared Balow
    it was pulled from a runnin car, and apparently ran well while in the integra. we swapped the whole motor and trans. how would i check something like that, would i have to bring it somewhere, and do u think that would be exspensive.
    redrex
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      I would start with the timing like nick said earlier. I had the timing set by ear/feel on Megan's CRX earlier this summer and it ran 2 seconds slower at the track. Turns out it was off by 2.5 degrees. Use a timing light. 🙂
      • J Offline
        J Offline
        Jared Balow
        what is a timing light and how do u use it
        redrex
          No offense but you did a motor swap and you don't know what a timing light is or how to use it? Cam gears could possibly be off if its that far down on power.
            yeah...how does that work....you swapped a motor...but yet you still dont know half the shit about motors ??
            • J Offline
              J Offline
              Jared Balow
              sorry ive never heard of a timing light. i didnt go to school for this and no one has ever mentioned one before. thats why im asking for help, if i knew everything i wouldnt ask. thanks for all your help though
              redrex
                pin
                A timing light either uses induction to detect voltage through the #1 spark plug wire, or it hooks up to the distributor. You disable the ECU's control over the timing, loosen the distributor just enough to rotate it, locate the timing marks on the engine and crank pulley, run the engine, point the light at the timing marks, and squeeze the trigger. Then you rotate the distributor very slightly until the timing is set where you want it.
                Barry
                • J Offline
                  J Offline
                  Jared Balow
                  k thanks
                  redrex
                    aliengotpsi
                    hmmm......
                    Kevin Smith
                    Straightlinedetailing.com
                      so how are the kids?
