  4. New Toys (ITB's)
New Toys (ITB's)
22 Posts 10 Posters 1.8k Views
  • stephen bradleyS Offline
    stephen bradley
    good luck ya big pimp you.
    • Unknown
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      harwood39 wrote:
      If you just bypass it and use tps based tables, you have really bad gas milage for daily driving.
      That is why you tune your maps. If you tune them to 14.7 low load through 13.2 heavy load your gas mileage won't change.
        "hail to the sled god" er i mean, d series god(if thats a title worth mentioning)haha jk
          This is prolly a good example why it is easier to go boosted.
              Im doing a lot of airflow testing right now w/ Z6 and Y8 heads an intake manifolds as im working on building sheetmetal intake and doing some head work on them. The stock Y8 intake manifold will flow enough cfm to not start choking down the power until 7500 rpm(based off a 250hp car). Based on those #'s alone there's no way your maxing out airflow of the stock intake running a stock compression/cam SOHC, let alone reving to the stock limiter.
              • harwood39H Offline
                harwood39H Offline
                harwood39
                so now why does every one think im in over my head? The hardest part will be tuning.
                oh ya, and im not doing this because i am maxing out my stock intake mani, im doing it for the throttle response and HP numbers.
                2730 5th Ave S. Unit C
                Fargo, ND 58103
                701-429-3686
                  This is true....but the hardest part is always tuning....ITB's (I'd imagine, don't know for sure) almost have to be harder to tune than a single TB. Just my thoughts.
                    harwood39H Offline
                    harwood39
                    oh, and i forgot to mention that when they were on groshongs hatch they run fine untuned, they just idled choppy but at WOT they were fine.
                    oh and ITB's are harder to tune due to the fact that they all need to be adjusted individually also just like a carb.
                    Fargo, ND 58103
                    701-429-3686
                      It's ok, they will be for sale in a week when he wants a new project anyways! 😛
                        harwood39H Offline
                        harwood39
                        ^^^ nice try but now they wont.
                        Fargo, ND 58103
                        701-429-3686
                        • bluejaysB Offline
                          bluejaysB Offline
                          bluejays
                          what brand are they? i'm guessing not toda.
                            pin
                            They're from a Suzuki GSX-R motorcycle. http://www.homemadeturbo.com/tech_projects/itb/
                            Barry
                            • M Offline
                              M Offline
                              MazdaMP3ShiftR
                              put thos on and race me!!! sohc vs sohc
                                harwood39H Offline
                                harwood39
                                Wont be on til next summer guys due to tuning issues i would have. and i would also want to dyno tune it once i get a good EMS.
                                Fargo, ND 58103
                                701-429-3686
