  4. Water injection
Water injection
21 Posts 7 Posters 6.1k Views
    Schwanger
    I'm not talking about spraying it onto the intercooler, I'm saying that you spray it into the intake. Many WRC teams use it.
      take a look at your sig and think about whether or not its worth the headache
      • dubbsyD Offline
        dubbsyD Offline
        in the upper intake
        Same thing, his is just spraying over his IC on it's way through his intake
          Schwanger
          It's realy not the same. You have to run a pressure sensor in your intake (MAP) so it it only injects after a certain pressure. The water is then absorbs some of the heat for the intake air and is passed through the engine where it leaves as steam through the exhaust.
          From what I've read it is completely worth it if you want to run a lot of boost. You can run much higher boost without having to retard the timing or dump a shit load of useless fuel in just to keep it from predetonating.
            http://www.3sxperformance.com/alcoholinj.asp
            id order a bottle or two of advil while your at it
            I think your better off spending your money somewhere else in my opinion...
            • AcesHighA Offline
              AcesHighA Offline
              AcesHigh
              Water-to-air intercooling and Water Injection is different. I don't know if it's been done around here in Fargo, but I think it would be too problematic considering our climate. Water freezes easily and often here.
              Nitrous does exactly the same thing as you described above, except with its evaporation it also releases oxygen. Not only does it cool your air charge, it would make oxygen more readily available. Water would not make the intake charge denser.
              • dubbsyD Offline
                dubbsyD Offline
                beats head against desk
                (I give up)
                  Schwanger
                  You can mix up to 50% alcohol in with the water which would keep it from freezing. Water is free nitrous isn't.
                  Water would make the intake charge denser. The liquid water "absorbs" some of the heat from the intake air, so the liquid then turns to steam. So the cooler intake air would then be more dense.
                  I don't think it's as big a headache as you think 92BlackTT, there are 2 adjustments on the less expensive kits, water metering (jet size) and timing (Pressure switch). The pressure switch can be set anywhere from 3-30 psi and comes preset at 10 psi.
                  I just wanted to bring it up, I'm not saying it's the solve all solution. I'm playing the devils advocate.
                    less expensive kits = total waste of time for what you are trying to accomplish
                    more expensive kits = possible/more then likely eprom, ecu output links to alc/water injection module, mapping experience, enough fuel injection knowledge to attempt this on your own motor not to mention tapping the intake manifold for the extra injector. Now stop to think about retuning your car on the dyno(you were tying to gain hp right?) and having an egt and knock box on hand to make sure it keeps working correctly. Is nitrous sounding better yet?
                    my head hurts just thinking about it..
                      Water injection is for people who don't have the proper FMIC and or fuel setup to keep their detonation under control. I too say spend the money and time on something like a fuel pump, injectors, AFPR, FMIC, etc.
                      • J Offline
                        J Offline
                        jake
                        Jake
                        • J Offline
                          J Offline
                          jake
                          There are some really good water injection kits out there. It's benefitial to spray into the inlet of the intercooler to reduce the intake temp as much as possible. Plus water is cheap, and with a good controller the water is only injected when it's needed, so you don't need a huge reservoir.
                          I agree that a properly set-up street configuration should not require water injection, but it surely couldn't hurt at the track. It could also be cheap engine insurance. The high-dollar controllers monitor things like boost, IAT, det, TPS, EGT etc. so they react quickly to your driving conditions.
                          If you have a large enough intercooler, it will act as a heat sink to help prevent temporary intake temperature spikes, but the water injection squirt will always be a little late getting to the engine.
                          I used to work with a guy who used this kit http://www.aquamist.co.uk/ on his Lotus Esprit 2.2 turbo, and he had really good luck with it.
                          This is a really inexpensive DIY kit:
                          http://www.autospeed.com/cms/A_0527/article.html
                          There are 6 parts to this article, you have to search for them and open them separately. Prices are here:
                          http://www.autospeed.com/shop/category_705/browse.html?
                          The autospeed kit looks like a pretty good deal. Are you looking at turbo-ing the Civic, Schwanger? It's too bad they don't allow water injection in FSAE. I'd be all over that.
                          Jake
                            Schwanger
                            The point of water injection is to use it along with your FMIC so you can run more boost. Water is a more effcient cooling technique then using an air-air IC.
                            Of course you wouldn't need it for the street, but I found a guy that uses it on a bike that he races at the Bonneville salt flats. The motor runs 11:1 compression and then he's boosting at 22psi. There is no way he could fit a big enough IC to keep it from detonating, so along with an IC he made a custom water injection kit.
                            No jake the Civ isn't getting a turbo. I can't afford it after I bought the Monster.
                            I was going to ask you if we could use it on the next car. Does it say in the rules that we can't use water injection?
                              thats exactly what troy said...he said if you didnt have the proper FMIC setup or fuel setup...
                                and for GSRs sake psi doesnt kill motors....:)
                                • AcesHighA Offline
                                  AcesHighA Offline
                                  AcesHigh
                                  There is alot of mix and match usage with the terms 'water injection' and an 'air-to-water intercooling'. In an air to water intercooler the intake charge is cooled by water inside the heat exhanger core. In a water injection system, water is directly injected directly into the intake charge and goes into the combustion chambers. It's a slight technical difference, but it shouldn't be used interchangeably. They both help prevent detonation.
                                    Schwanger
                                    Jake, do think that water injection would provide better consistency over an air-air intercooler?
                                      Schwanger
                                      1. We shall see the effectiveness of an intercooler.
                                        The efficiency of a intercooler relies on the following factors:
                                      1. Frontal area.
                                      2. Pressure drop across the cores (external and internal).
                                      3. Road speed.
                                      4. Air temperature differentials (external and internal).
                                        To simplify the calculations, given that there are so many variations in size and efficiency. We start with an intercooler with 50% efficiency. We will calculate how much heat is being removed for a given mass airflow based on a boost pressure ratio of 2 at 6000 rpm, using the same 2-litre engine. The result will be used to compare against a water injection system. Ambient air temperature is 25°C and the compressor exit temperature is 124°C. At 50% intercooler efficiency (reasonable assumption as both the engine and intercooler is operating close to their peak flow limits), the temperature drop across the inter-cooler should be:
                                        (124°C - 25°C)/2 = 49.5°C. The final air temperature entering the engine is 74.5°C.
                                      1. We shall see the intercooling properties of water injection.
                                        Water temperature is 25°C and the compressor exit temperature is 124°C and Water flow rate of 250cc per minute. In the region we are working in the partial pressure of water vapour in the mixture is very low. We can assume that the enthalpy is a function of temperature alone within reasonable accuracy (e.g. for 250g /min of water and 8.64Kg/min of air, the partial pressure of water in about 0.06 bar). Consequently the final temperature is an inverse linear function of water proportional as nearest makes no difference. The calculation and results:
                                        At 200cc/min: 66.09°C
                                        At 250cc/min: 50.88°C
                                        At 300cc/min: 36.27°C
                                        So there we are, we have proved our point, water is just as effective as an intercooler. We decided to calculate a few more water flow rates so that a chart can be plotted, useful for visual prediction. Even at a modest flow rate of 200cc per minute, water is a better cooler than a 50% efficient intercooler by a long way. Notice at 350cc/minute of water, the final temperature dropped below the ambient of 25°C !!! there just isn't a 110% efficiency intercooler around yet ...
                                      all of this was found at http://www.turbodynamics.co.uk/water.htm
