  4. My Poor Poor Evo
My Poor Poor Evo
21 Posts 11 Posters 2.5k Views
    Can't be any worse then the S4 we did on the floor @ the old shop. That was pure HELL!!!
      or a CAI on a STi, that was pure hell to(ask kevin...im not good at telling stories)
      • W Offline
        W Offline
        Wizard
        I did one on my old roommates 03 EVO. Brandon Griffith. His went at about 15k too. That was about 30 passes. Best ET was 12.66 with 2.5" test pipe with a dump pipe, K&N, MBC and AFC. Was able to get 1.69 60ft on stock clutch and street tires. It was a PITA even when compared to a 2g. Kinda tight in there. Even worse than 2g. Ended up putting in a Exedy clutch.
        As for the clutch......you will find that almost no manufacturer will cover a clutch after 10,000 miles. Especially on a performance car. They are not stupid guys...come on.
        A clutch is like brakes....wear item. Why should they fix it under warranty when it's your fault? Even though the motor may be covered to 60k, if you don't change your oil and it dies at 21,000miles....guess what? It's not their fault. Warranties are for defects and workmanship errors only. If they do change it for you, you're lucky and someone is being nice or stupid.
        As for the tires....i'll agree they are kinda crappy. But according to the owner's manual, you have to rotate them every oil change or uneven wear will occur. We changed his tires at around 15k as well. Mostly because he rotated them once at 6k and at 15k they had worn badly. Really soft tires. Ended up installing BFG Comp T/A ZR4s and that was the 1.69 60ft. Best on the old tires was 1.74 or so. And the BFGs are rated to 25-30k miles.
        Wiz
        1992 GVR4 598/1000 Nile Black
        1992 Tsi AWD
        1982 Datsun KC 4x4
        1990 Laser 2.0 AT NT
        1994 ES 2.0L NT 5-spd
        • tntmstrT Offline
          tntmstrT Offline
          tntmstr
          yeah we have done 2 of them already. They are fun!!!!!!!!! Just make sure you go with a good clutch. So you don't have to do it again. We used an ATS for Coles EVo. (Carbon Twin Disk). Pretty bad ass when you have to "heat" up your clutch before you launch. haha
          Jason Christopherson
          Store Manager
          Tintmasters
          Fargo, ND (701)239-TINT
          www.tintmasters.net
            is cole the blue evo? whatever happened to him, shane?
            • tntmstrT Offline
              tntmstrT Offline
              tntmstr
              Cole had a black Evo and Valley could not get it to run after 15,000 miles so they gave him a new white one. they had his car for 5 months and sent it back to Mitsu. this new one is having some of the same issues. He is going to go with AEM and that should fix his "issues".
              Store Manager
              Tintmasters
              www.tintmasters.net
                Which CAI did you go with? From what I can tell the CAI on the STi mounts the same as the WRX and wasn't just too bad...except that you have to remove the fender liner to get the filter on/off. Should be like a 20 min job at most....at least my APS was.
                  It was a custom made one SLS ordered from some guy in Japan(never got a name..), the project itself didn't take long, it's just teh fact that kevin was widening a part on the intake with a drill and was holding it with his legs and drilling it and the drill accidentally went through the part to fast and kevin got drilled right into the leg, his pants got all tore up and what not. ugly scene.
                    probe this
                    My roommate had the blue one, but it was having issues and after Valley had it for a month they finally bought it back, now he has Steve's 98 talon. 😄
                    My probe is fast. How fast? Line up next to me at the track and find out.
                    I can pull my probe faster than most ricers can race. haha
                    99 black lightning 496whp, 620ft/lbs heavy pig
                      i woulda been like gimme a new evo MR bitch
