  4. More People Should Sign This
59 Posts 25 Posters 3.7k Views
  • camzaro28C Offline
    camzaro28C Offline
    camzaro28
    Quote:
    Originally Posted by camzaro28
    does anyone know the real reason for them being on the front?
    i have yet to think of a logical reason
    I know and use a reason every day Im at work. Drive off prevention. I check out the licence # on the cars that start pumping gas all the time. If there wasnt one on the front, I wouldnt see most cars plates.
    very good reason, that didnt come to mind. but dont most gas stations have cameras? most i do see, say on the pump that u are being videotaped 😕
    jig 4 prez
      camzaro28 wrote:
      so 1 of the 3 didnt have front plate? still not a reason
      No one did genious. hence the reason for identification. Wow, I thought a camaro driver would be a little smarter.
        TDuck
        To me, by placing your plate on your dash so it shows through the windshield says that you know better and are trying to get around a law.
        15 years ago I had a 1984 Thunderbird. For the first couple of years I had a front plate, then I bought a full bra for it. I removed the plate. I never had a single problem with not having a front plate. I never had it on my dash so it showed through the windshield. No tickets and I screwed around A LOT.
        I was not aware back then that by not having a front plate was illegal but never had any issues either.
        TDuck
          94NDTA wrote:
          Thats pretty much how it works.
          BULLSHIT
            ichibankilla wrote:
            Century Code 39-04-11
            Click Here
            It just said that the plates have to be dispayed in an upright position on the front and the back of the vehicle. Which is a very broad description, so technically in your windshield, as long as it's displayed properly there, should be legal. But then again we all know how some cops seem to make up the laws as they go.
            for those too lazy to look it up:
            NDDOT wrote:
            39-04-11. Display of number plates and tabs. Except as otherwise specifically
            provided, a person may not operate or drive a vehicle on the public highways of this state unless
            the vehicle has a distinctive number assigned to it by the department, and two number plates,
            bearing the distinctive number conspicuously displayed, horizontally and in an upright position,
            one on the front and one on the rear of the vehicle, each securely fastened, except number
            plates assigned to a motorcycle, trailer, or housetrailer must be attached to the rear thereof.
            When only one number plate is furnished for an apportioned vehicle licensed under the
            international registration plan as authorized in section 39-19-04, truck tractor, or semitrailer, the
            plate must be attached to the front of the apportioned vehicle or truck tractor and the rear of the
            semitrailer. The bottom of each number plate must be at a height of not less than twelve inches
            [30.48 centimeters] above the level surface upon which the vehicle stands. Each plate must be
            mounted in a manner that does not cover any words, letter, or number on the plate. As far as is
            reasonably possible, the plates must at all times be kept free and clear of mud, ice, or snow so
            as to be clearly visible and all number plates, markers, or evidence of registration or licensing
            except for the current year must be removed from the vehicle. All vehicle license plates issued
            by the department continue to be the property of the state of North Dakota for the period for
            which the plates are valid. An annual registration tab or sticker for the current registration year
            must be displayed on each number plate, in the area designated by the department for the tab or
            sticker, in those years for which tabs or stickers are issued in lieu of number plates.
            • 94NDTA9 Offline
              94NDTA9 Offline
              tjamz wrote:
              BULLSHIT
              Your sarcasm detector must be busted.
                Yup...it is.
                • 94NDTA9 Offline
                  94NDTA9 Offline
                  tjamz wrote:
                  Yup...it is.
                  IT's ok. I will adjust my posts for you.
                    CCr wrote:
                    And the being grandfathered in thing? Every vehicle by law is required to have seat belts, there is no grandfathering. I checked into it and ran the risk of getting the tickets.
                    I have never heard a model A or T owner ect tell me to look at their snazzy new seatbelts? I have sat in a couple kit cars that dont have them either? I dont mean to push this thread off topic or anything.. but wouldnt that mean that you need an air bag too? if nothing is grandfathered in then id like to see the mint 1932 fords that were crashed to make sure they are safe for our public streets.
                    seatbelts were only an OPTION from the factory in the 50s..
                      well said mitch
                        They were actuall an option up until 1965 when federal law mandated their placement. about %25 of 65 mustangs, and a very small percentage of 66 mustangs were made without them. old guys with Model t's, Of course they never brag about it? Why would they? They don't want to install them. Neither do I. As far as air bags, air bags are not required by law to be on the vehicle when it is on the streets. They are mandated from the factories I believe.
                        I'm not rereading my old post, but if I said that nothing is ever grandfathered I know that's wrong. I was speaking specifically of seat belts not being grandfathered.
                          -> CCr wrote:
                          And the being grandfathered in thing? Every vehicle by law is required to have seat belts, there is no grandfathering. I checked into it and ran the risk of getting the tickets. I don't have front seatbelts in my car.(Put them in to go thru a dui checkpoint a few weeks ago, not using them, taking them out again this weekend)
                          Wrong again Pete!
                          ND Century Code 39-21-41.1 wrote:
                          **39-21-41.1. Safety belts.
                          **1. Every passenger car manufactured or assembled after January 1, 1965, must be
                          equipped with lapbelt assemblies for use in the driver's and one other front seating
                          position.
                          1. All motor vehicles manufactured after January 1, 1968, must be equipped with any
                          lapbelt or shoulder belt required at the time the vehicle was manufactured by
                          standards of the United States department of transportation. Nothing in this
                          subsection affects the requirement in subsection 1 for a lapbelt in the driver's seating
                          position.
                          1. The department may except specified types of motor vehicles or seating positions
                          within any motor vehicle from the requirements imposed by subsections 1 and 2
                          when compliance would be impractical.
                          1. No person may install, distribute, have for sale, offer for sale, or sell any belt for use
                          in motor vehicles unless it meets current minimum standards and specifications of
                          1. Every owner shall maintain belts and assemblies required by this section in proper
                          condition and in a manner that will enable occupants to use them.
                            tjamz wrote:
                            Wrong again Pete!
                            [/left]
                            [/size][/font]
                            Well, I'll be. I was gonna ask you to look it up too. I'd like to thank 3 police officers and a judge for making me look like a complete retard today(most other days it's my own fault).
                            and what else was I wrong about? I forgot.
                            Edit:Police Chief Magnus
                            "The N.D. Century Code requires drivers and front seat passengers of vehicles to wear a "properly adjusted and fastened safety belt."
                            That is from the 11/9 chat with the chief. How does that affect my arguement? It mandates wearing a seatbelt. To wear a seat belt, the vehicle must be equipped. Therefore all vehicles must be equipped. Help me on this Chuck. Is that accurate?
                              They are wrong according to the century code
                                where can you get century code copies online? THis would be nice so I'm not a complete jackass in the future, just mostly a jackass.
                                So just to clarify it doesn't say anything about "properly adjusted and fastened safety belt"?
                                  http://www.state.nd.us/lr/information/statutes/cent-code.html
                                    Thanks for that post, it is now bookmarked. My jackass day is over. and all you had to mention was the 39-21-41.4 "a driver may not operate on a highway a motor verhicle which was designed to carry fewer than 11 passenger, which was originally manufactured with safety belts unless each occupant is wearing a properly adjusted and fastened safety belt" That woulda answered it better. So again Thank You.
                                      you asked where to find the century code, so I posted the link
                                        we coulda saved some of the other post, but we're good. As I said thanx for the post.
                                        • C Offline
                                          C Offline
                                          CivicEX7777777
                                          Laws are confusing sometimes
                                          2007 Pontiac G5
                                          2007 Yamaha C3
                                          2002 Oldsmobile Alero
                                          1994 Nissan Sentra
