  4. my new car
my new car
37 Posts 13 Posters 1.6k Views
  • krzydrftr93K Offline
    krzydrftr93
    he is just like shane.. spend money on cars not worth put money into but hey whatever they are enjoying it
    Matt
    92 Civic HB
    JDM d15b w/14b@8psi
    • assasainA Offline
      assasainA Offline
      assasain
      lol yep.... i dont care if its worth it i just wanna have fun :):):)
        krzydrftr93
        Thats what its about in my mind. Get some decent hp out of that thing and it could be a lot of fun
        Matt
        92 Civic HB
        JDM d15b w/14b@8psi
          shane it never needed a new wiper motor, just for it to be put back in...
          • C Offline
            C Offline
            CivicEX7777777
            Oh I thought you said it needed new one, thats part of the reason why i couldnt get it
            2007 Pontiac G5
            2007 Yamaha C3
            2002 Oldsmobile Alero
            1994 Nissan Sentra
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              Check out www.club4ag.com. There are a few engines that bolt right in. Sucks that you have a non-lsd rear and other things, but oh well. I would probably just beat the shit out of it as it is, more fun that way.
              • assasainA Offline
                assasainA Offline
                assasain
                i already joined them i just havn't posted yet.... thanks 🙂
                ya i actually got it so the trunk latched and stays but havn't got it to be able to pop open, but i did install the windshield wiper motor and wipers and now those work too....... next thing to work on is the dash lights then the clutch and onward from there......
                  Here I looked up the diffrence between the Gt-S and the Sr-5. It's going to take a ton of work/money, but good luck.
                  4A-GE engine (and all brackets to support peripheral equipment)
                  2.
                  Most peripherals such as A/C, P/S pumps and compressors
                  3.
                  Complete intake and exhaust runners and headers
                  4.
                  Fuel pump and lines
                  5.
                  Gasoline tank, evaporation and related items
                  6.
                  Clutch fork and fluid line locations and bell housing (GTS and SR5 has opposite side clutch fork and slave due to the differences in the exhaust runner location and is extremely important not to run fluid lines next to exhaust systems)
                  7.
                  Transmission is the same unit as the GTS (T50C), however the speedometer gear is different, and must be replaced to read correct speed on the cluster. (due to different final drive ratio)
                  8.
                  EFI computer triggers and sensors
                  AFM or MAP
                  Air Temp Sensor (MAP only)
                  distributor assembly (MAP and AFM based are different)
                  Igniter and Coils (different for AFM and MAP based)
                  EFI Computer (MAP or AFM specific)
                  House Harness and Engine Harness and related junction boxes
                  All relays and VSV triggers
                  peripheral VSV triggers
                  Battery terminals and fusible link terminals and fuse box
                  some of these can be ignored for carburetor use such as Weber Side-draft carburetors
                  9.
                  Ignition system
                  10.
                  Dash Cluster missing check engine (W) lamp
                  11.
                  Labor and Installation Professional who can proceed properly so as not to create more problems (cheap or un-skilled installer would render the 4A-GE less powerful and unbelievably unreliable.
                  12.
                  Oil cooler, block and lines
                  13.
                  Clutch and flywheel
                  Now as for other items that are mechanically different from the GT-S (4A-GE equipped models):
                  Differential carrier
                  2.
                  Differential gear, axles, hub assembly (need 4A-GE unit to utilize commonly available LSD)
                  3.
                  Rear disk brakes vs. drum and related lines and cables (except Japanese GT)
                  4.
                  Steering rack, knuckles, tie rods
                  5.
                  Propeller shaft
                  6.
                  Clutch fork, assembly, cables, lines, bell housing (as mentioned above)
                  7.
                  Front and rear suspension are different from factory in spec but can be interchanged (Not significant as most owners replace them with aftermarket systems anyway)
                  • AcesHighA Offline
                    AcesHighA Offline
                    AcesHigh
                    2.
                    3.
                    4.
                    Fuel pump and lines
                    5.
                    6.
                    7.
                    8.
                    AFM or MAP
                    9.
                    Ignition system
                    10.
                    11.
                    12.
                    13.
                    Clutch and flywheel
                    2.
                    3.
                    4.
                    5.
                    Propeller shaft
                    6.
                    7.
                    owned 🙂 have fun
                      we already knew it was very different...
                        krzydrftr93
                        Well start saving now and maybe by this time next year you will be ready to start the build.
                        Matt
                        92 Civic HB
                        JDM d15b w/14b@8psi
                        • 3_Series3 Offline
                          3_Series3 Offline
                          3_Series
                          2.
                          3.
                          4.
                          Fuel pump and lines
                          5.
                          6.
                          7.
                          8.
                          AFM or MAP
                          9.
                          Ignition system
                          10.
                          11.
                          12.
                          13.
                          Clutch and flywheel
                          2.
                          3.
                          4.
                          5.
                          Propeller shaft
                          6.
                          7.
                          Did he ever say he was gonna do a GT-S conversion? He only mentioned a motor swap...
                          2002 Subaru Legacy
                          1993 BMW 325i (sold)
                          • sitn2loS Offline
                            sitn2loS Offline
                            sitn2lo
                            waste of money... just use it as a winter beater dont swap it (but also if u think u can do it then do it.)and dont put the gay ass apc shit on it....like someone on here did...
                            Yukon Denali on 22's
                              krzydrftr93
                              I dont have anything APC on my car. I have AEM intake Cf spoon mirrors from jdmcarboy, CF spoon style spoiler from tintmasters type r titanium shift knob and type r red stiched shift boot from tintmasters and tint from them. Saving for password:jdm sturt bars or jic magic bars. SO I DONT HAVE GAY SHIT ON MY CAR ALRIGHT.
                              Matt
                              92 Civic HB
                              JDM d15b w/14b@8psi
                                Who are you talking to? Everybody already left this thread already screaming, I just dropped by to turn out the light...
