  3. Run Your Mouth
  4. New Record
New Record
24 Posts 10 Posters 4.0k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    mine was a granading clutch. motor wise fine, but i decided to upgrade the internals a little on my motor while i had it out. Plus my motor was fuckin nasty, it was so dirty and grimy on the inside. plus i had calcium deposits on the valve train, dont ask me how, and bearings and rings were a little worn and tired. So i just decided to do it all.
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      at least i didnt pull a motor to change a clutch...dur
        Grip!
          97Cav wrote:
          i think he has done one better then me!!!!
          it's your old head on the slo that went...hrm...you bounce rev limiter forever with it @ 7900 give or take...matt runs a 75 shot through it and revs it to 8k, i rev it to 7500 and lets go..???...idk wtf happend with that thing...o well, got a new head for it anyway...it'll be runnin as soon as the shop is done with the machine work...and the laser will be running by next week too (got a head with good valves for it). That was just bad luck or somthin, im not quite sure why the timing belt decided to slip 8 hrs. before track day...so then we are down back to the AWD being the only one down again...still not good, but better...i do think the car god is against me in this lol
            BumpinJCC wrote:
            Grip!
            a big one!
              PSiedTSi wrote:
              you broke a stock SOHC D-series too...
              mine wasnt quite stock...stock ZC bottom end, z6 head with zex stage 2 cam, exedy stage 2 clutch...close though...still not over 150hp...still slow...just not as slow lol
                aliengotpsi wrote:
                dude he must be the worst mechanic of all time! lol
                (in my best Cartman voice) i hate all u guys o so very much 😛
                  harwood39H Offline
                  harwood39
                  no, i pulled the pan, found out the bearings were fine, pulled the motor to build it, i had plans of building the motor up this winter NO MATER WHAT. I planned building the motor since the middle of summer. So i guess you can give me all the crap you want, but at least i am doing everything right and taking my time with it.
                  Also, i believe the head went because YOU beat on it and braught it up to rev limit ALL THE TIME WITH a comp cams 260 grind cam on STOCK valve train. That is why the head went. Ask EVERY ONE. matt only braught it to 8000 10 times with the cam. other than that he didnt beat on it with the cam in there for that reason. That is also why the recomend springs and retainers, so you dont float valves.
                  Fargo, ND 58103
                  701-429-3686
                    ok harwood....he's pissed about somthin ^^^^ lol
                      harwood39H Offline
                      harwood39
                      im not pissed, im just stating the truth, matt and i had a LONG conversation about you and blowing motors, oh, bartels was part of it too.
                      Fargo, ND 58103
                      701-429-3686
                        oh and me and matt talked about it oo!!!!!!!
                          harwood39H Offline
                          harwood39
                          ^^^see, i have a few people that can agree with me on this one.
                          Fargo, ND 58103
                          701-429-3686
                            ok harwood
                            • NickBN Offline
                              NickBN Offline
                              NickB
                              You guys are pathetic, go talk about this on AIM or in person...No one wants to hear your gay relationship problems
                                accord dude there ^^^...dont PMS about it man...this is just a dink around thread i guess...so you dont need to take it so seriously...and if you dont wanna hear about it, then dont read it!...its the simple solution to all of your problems 🙂 ...have a nice day!
                                  Its a d series it takes 1/2 hour tops to pull. Who cares if he pulled it. STFU DUDEZZZZ>!
