  4. Definitions of turbos
14 Posts 10 Posters 1.7k Views
    it all depends on how much money you want to spend and how much hp you want to get
    what are your goals?
      stages of turbo kits can mean different things for different manufacturers... the best thing to do would be to post up what is included in the kits including turbo specs, and we could help you estimate what type of power you could expect from a setup like it.
      • J Offline
        J Offline
        JDMSTi
        power doesnt just explain it all either...do you want alot of HP, have lag and have a huge gush of accelleration? or do you want fast response with boost almost all of the time and and sacrifice some of the top end performance? Look at your uses or intended uses for it and then decide...there are compromises in every setup
          Tad218
          kinda off subject is it aright to use n2o with an auto tranny
            if it can handle the torque....you might wanna think about gettin a shift kit too if available...
              seanjohn
              Yeah, it's not a problem.
                pin
                Wtf is up with the thread hijacking??
                To the thread starter, check this out: http://auto.howstuffworks.com/turbo.htm
                Barry
                  That is a great educational web site for novices.
                    So it should be good for you and your slow accord..haha
                      Your so mean 🙂
                        At least I don't drive a Taurus w/ a bad tranny 😛
                          The one that beat you from a roll.....
                          Update: Handoex is buying a cold air intake, watch out now.
                            no I'ma gonna trade it in for a Buick 😛
