  4. Honda help...
Honda help...
7 Posts 5 Posters 410 Views
  • 91nbtsi9 Offline
    91nbtsi9 Offline
    So, I figured I would help my mom out since she got screwed over by Corwin, long story, but she needed a new engine in her 1999 Accord. So, I get an engine with 24000 miles on it, swap parts over, put it in her car. I am having a hell of a time getting it to run correctly. When I hit the gas at all it just wants to bog like it is running out of fuel or something. Compression is at 175 psi across the board, fuel pressure is at about 75 psi, swapped distributors multiple times (so I assume spark is good), swapped throttle body with MAP and TPS sensor. The car starts right up, idles, but as soon as I try to rev it up at all it falls on its face.
    Anyone has any ideas, I am sick of pulling my hair out. :mad: This was supposed to be easy money!!! heh
      how is the altrenator in it???? i know you might be thinking what the fuck are you talking about.....but in the 99 accords for some reason when the alt. is fucked up......everything is fucked up.....
      happened to a friend of mine and he just replaced the alt..and now it runs fine again.
      although he has the 3.0v6.....if thats what engine ur talking about.
      • ticklemedalyT Offline
        ticklemedaly
        i dont think that this will effect anything, but that fuel pressure seems awefully high. If you are desperate, bring it by my buddies shop that I work at, we can figure it out for you.
        Ry
        West Fargo Car Clinic
        100 West Main
        West Fargo
        701-277-7288
        XBL G-tag: TickleMeDaly83
          Just swap the plugs for the map and TPS sensor around.
          • 91nbtsi9 Offline
            91nbtsi9 Offline
            Thanks GSR!!! Like I said guys, I had checked everything.... I guess I never thought an automaker would make two plugs the same for two important sensors that are right next to each other!!! Damn Honda.
            Thanks GSR, you ended my depression.
              ticklemedaly
              wow, I didn't suspect that, ill keep that in mind. Good Job, and good luck with the newer engine.
              Ry
                his nickname isnt a honda car for no reason...
