  4. Need ideas to build up a CRX
14 Posts 9 Posters 847 Views
    JW. How much did you buy it for?
    • ErikE Offline
      ErikE Offline
      Erik
      I'd give it a d16 vtec (d16z6 or d16y8) for a nice little power boost, then turbo that later. Its pretty much a direct swap if I remember correctly. And the tranny that comes with those engines is real short and should suit your acceleration needs.
      And I'd like to try to talk you out of the 17's. 15's or 16's maybe?
      They call me, old man...
        I'd say D16Z6 you can use a CRX SI tranny, bolt in swap
        • youngin2nrY Offline
          youngin2nrY Offline
          youngin2nr
          what year is it? What kinda power you looking to make with it? What kinda future mods besides motor swap and turbo?
          :3gears: -> :drink: -> :poon:
            i would do a d16z6 or d16y8 swap. but if you want something alittle bit bigger motor wise i would try for a b16 or a LS/vtec. for exhaust it depends on what style your looking for. sometime if your get a performance exhaust it might be really loud, at least the one i had was. you might be able to find an exhaust system that is queit when your off the gas and it will be louder when you get on it. if you have any questions you can send me a pm and i will try to help you out as much as possible.
              Those trannies won't go into CRX's without a conversion kit cuz they are hydro and CRXs are cable. But find an Si tranny if you go with d-series.
              • wa2fastcamaroW Offline
                wa2fastcamaro
                Thanks for all the info sofar. I am gunna need a lot of help building this car, since I am all new to Honda's. So anyone that wants to come over and help, woul dbe much appeciated. Just need to decide on a enigne and then we can get started. I would like to get the enigne done after christmas.
                I was just looking at a spec thing and this engine makes 62HP, lol. Definatly need to at least double that.
                Mike
                Boys and Their Toys Auto
                Phone: 701-371-5615
                E-mail: [email protected]
                  wa2fastcamaro
                  I have been looking at things, the B16A seems like a good engine, makes quite a bit of power. What do you think?
                  Maybe I should just buy this. I could convert the car to right hand drive too, lol. I wish I had that much cash.
                  JDM CRX Clip
                  Phone: 701-371-5615
                    Don't do a B16, if you're going B series, do an LS motor. They are very cheap, and perfect for turboing. I bet if you were to put a stock B16 swap and a stock LS swap into 2 CRX's, the LS would keep up if not win.
                      Or do an LS VTEC if you have $$$
                        Contact teg2low on this forum cuz he has an LS vtec motor and like 2 vtec heads for pretty cheap. And he is a good guy to deal with.
                        • darkelvisD Offline
                          darkelvisD Offline
                          darkelvis
                          Check your PM's. If you want I can stop by tomorrow (after 2:00) and throw some ideas at you. 🙂
