  4. Plane on a conveyor belt
298 Posts 57 Posters 19.2k Views
  • dubbsyD
    dubbsyD
    Sweet-WRX-Lovin wrote:
    The plane will take off. The conveyor will keep matching the wheels speed but the plane itself will continue to move forward in space due to it's propulsion being independent of the restrictions imposed by the conveyor.
    actuall that is partiall incorrect..
    the conveyor will not match the wheel speed.. the wheel speed is the combined speed of the conveyor and the plane.
    • StormwalkerS
      StormwalkerS
      Stormwalker
      Here is another interesting link:
      http://www.avweb.com/news/columns/191034-1.html
      www.tcstangs.com
      • Ashli19A
        Ashli19A
        Ashli19
        The plane will take off because the wheels are entirely independent from the plane's engines. The engines on the plane create thrust=displacement of air. The engines draw air under the wings more quickly then they pull air over the tops (der thats a given) so if the plane's engines can generate enough lift, even though the wheels are spinning a bajillion miles an hour, it will take off. The plane doesnt have to physcially move to take off, it just has to move enough air under its wings. Think about the reasons cars have diffusers under them. If the car is moving too fast (AIR IS MOVING TOO QUICKLY NOT THE ACTUAL CAR) it will generate lift and lose control.
        -mitch
        edit/ I just realized that is pretty much what sweetwrxlovin just said
        • ichibankillaI
          ichibankillaI
          OK, so I went to the mythbusters site and was going to post this as an idea and come to find it's already on there in the discussion forum. It seems there is a video out there that proves that the plane WILL take off. So, if any of you are up to the task of finding it you're welcome to it, it's too late for me to search now but I might get a notion to tomorrow.
          • dubbsyD
            dubbsyD
            -mitch
            Mitch, if I"m reading this right...everything about it is wrong...
            #1. Air travels faster over the tops of wings.. This creates a low pressure that in turns sucks the wing up (bring the plane up with it)
            #2. The plane DOES have to physically move. The engines do not move enough air around the plane to create lift. ...but no matter what, when thrust is applied, the plane will move in relative space and the plane will take off just like there was no conveyor there in the first place.
            • amichezeA
              amichezeA
              maybe im just physics retarded (never did take the class) but i still dont see how the plane can take off. since the plane needs air to flow over its wings to take off - and since the conveyor exactly matches the plane speed (to me, meaning the plane doesnt move forward at all) - it cant take off.
              Fargostreet Trolls wrote:
              i must be stupid
              • Sweet-WRX-LovinS
                Sweet-WRX-LovinS
                Sweet-WRX-Lovin
                Right. It can't as the plane accelerates. Just tried the simple answer.
                Amicheze, the planes way of moving forward, thrust from the engines, is totally independent and free from the coveyor moving and the wheels. The wheels end up acting like bearings (which they are I guess) and the more the conveyor trys to hold the plane in one place while it moves forward, the faster the wheels will spin and that's it. The plane itself will just continue to accelerate forward while the wheels and coveyor just keep spinning faster and faster.
                In other words the conveyor and wheels don't exist and it's just the thrust of the engines moving the plane forward.
                One time...
                • lord_deastofactL
                  lord_deastofactL
                  lord_deastofact
                  well I thought about this one through and through debated it with my roommate and I descovered the crux of the issue, there are two schools of thought that will clash on this. the free thinkers and those who are bound to constraints. if you don't think outside the box, the plane will never take off. but since I don't think like that I came to the solution rather quickly. negating the obvious errors in the queston and assuming that by saying plane they ment airplane not aircarft and most certianly not just a "plane".
                  the solution I arived at is that since the question did not set any limitations on the craft, at a certian point the airplane would achieve an amount of pounds thrust that is greater then the mass of the aircraft. in essense turning the craft into a rocket and negating the need for wings at all. it will move simply by newtons laws of motion. and at such a point the only way to stop it from moving is to increase it's mass to something greater then what the engine is capable of producing thrust to compensate for. but no matter what with the right amount of thrust the craft will move no matter what. even if you tie it to the earth. with a amount of thrust that is totally unrealistic of achieving it would move the earth as well and become yet another spacial object.
                  but this is only taking into account that you do not limit the solution to restraints that the question never stated. this is how advances are made in science by forgetting about past flaws, if people didn't think like this, the earth would still be flat, the sun would revolve around us and apples wouldn't fall.
                  Minute ricer!
                  • amichezeA
                    amichezeA
                    ok. here is my line of thought..
                    let plane speed = A
                    let conveyor speed = -A (since theyre exact opposites of each other)
                    A + -A = 0 meaning no forward movement.
                    no forward movement = no flow over/under the wings = no lift
                    i understand your thoughts about how the plane's wheels will just keep spinning.. but arent the wheels attached to the plane? if so, if all the wheels are doing is spinning, how is the plane moving forward? to me it would be like trying to run on a treadmill. if its moving the same speed as youre running, your head wont go anywhere even though your legs are trying to move you forward.
                    i must be stupid
                    • 51d3w4yz5
                      51d3w4yz5
                      51d3w4yz
                      That is because your legs are your source of propulsion on the treadmill, for the airplane, it is the engines pushing air and the wheels have nothing to do with it. How do Ski/float planes take off without wheels, because they aren't necessary so it doesn't matter how the wheels are moving, the plane is pushing forward with air.
                      • Sweet-WRX-LovinS
                        Sweet-WRX-LovinS
                        Sweet-WRX-Lovin
                        It's a little different than that, in my opinion I guess. What you are assuming is that the planes ability to move forward is directly tied to the wheels (it is not I'm assuming in this situation). Let's use the treadmill analogy. You put a skateboard on a moving treadmill. If the wheel bearings of the skateboard are perfectly frictionless (like what I'm assuming with the plane's wheels here), the skateboard itself will not move. The wheels will spin with the treadmill, but the skateboard itself will not move. Now we have the wheels vs conveyor thing illustrated. They negate each other. The only force left acting on the plane is the thrust of the engines. This is the only force left (magically of course). Since it is the only force left, the plane moves forward and takes off.
                        One time...
                        • amichezeA
                          amichezeA
                          yeah the plane's jets are pushing it forward.. but gravity is holding the plane down onto the belt. since the wheels are actually what are touching the belt.. theyre just going to spin. ski/float planes dont take off of something moving the same speed in the opposite direction.
                          im trying to understand.. but my common sense (at 3 in the morning) says it cant happen.
                          edit: written before the above post. i think i got it.
                          i must be stupid
                          • Sweet-WRX-LovinS
                            Sweet-WRX-LovinS
                            Sweet-WRX-Lovin
                            That's a big 10-4 on the 3 in the morning biz. If I hadn't slept all day cuz I was working all night last night I'd be in bed so long ago. The gravity holding the plane down on the belt as a way of holding it from moving horizontally is negated by the magic of the ever popular assumed frictionless bearings. Lots of assumptions and whatever in all this bizness, interesting question Chuck 🙂
                            One time...
                            • dubbsyD
                              dubbsyD
                              Tjamz has a great analogy for this but I'll let him post when he gets bored and sick of watching you all hash it out. 🙂
                              oh, BTW. the plane will take off.
                              • 2wheeler2
                                2wheeler2
                                2wheeler
                                ok, heres my take....you need the airflow above and below the wings to make the plane leave the ground. If you've ever run on a treadmill, you'll know that you get hot because no matter how fast you run, there is no airflow going over your body. If you run around a track or outside or something, the airflow will cool your body.
                                With no airflow, the plane stays on the ground.
                                '08 Suzuki Hayabusa
                                '09 Yamaha Zuma 200cc
                                '95 E-350 7.5L
                                • bluejaysB
                                  bluejaysB
                                  bluejays
                                  in a perfect world with no friction or delay it wouldn't, but since the control system has to tune the speed it won't be instantaneous, which will allow the plane to start moving before the machine can actually "tune" the speed.
                                  • PhatsP
                                    PhatsP
                                    Phats
                                    So, Dubbsy
                                    Explain too me why the foreword thrust wouldn't move the tires more.
                                    Plane has thrust on it's body, pushing the plane a 50mph, the wheels, attached to the plane, spin at 50. The "Treadmill" spins at 50.
                                    The plane has thrust pusing it's body too 100mph, that means the plane needs too acelerate, forewords, because we need too go forwords to generate lift, we all know that.
                                    so, if the plane goes forword, the wheels turn forword, the Treadmill matches the wheels.
                                    Which means it matches the plane.
                                    Which means that it doesn't matter what speed the Jets are pushing the plane, the wheels are going that fast too, and as long as they are, the treadmill is matching.
                                    I understand what u are saying, but, it's not possible too me.
                                    If u can explain it, please do.
                                    02 GSXR-1000
                                    97 540i
                                    • PhatsP
                                      PhatsP
                                      Phats
                                      For the plane to move forword, the wheels must move forword, which means the tradmill moves the other way.
                                      Unless u can kill my theory.
                                      02 GSXR-1000
                                      97 540i
                                      • bluejaysB
                                        bluejaysB
                                        bluejays
                                        Phats wrote:
                                        So, Dubbsy
                                        that is what i was thinking, but that is in a perfect world.
                                        • StormwalkerS
                                          StormwalkerS
                                          Stormwalker
                                          I just thought of an explanation/analogy, let me know what you guys think of it.
                                          Reading a couple of the posts here, people like to try to think of this in terms of a treadmill, so we will use that.
                                          Imagine standing on a treadmill wearing a pair of rollerblades. Now, someone is standing behind you (off of the treadmill). Turn the treadmill on, and have the person behind you push you forward. Do you start moving forward in relation to the ground? Hopefully, the answer is yes.
                                          www.tcstangs.com
