  4. making fiber glass plyable?
11 Posts 6 Posters 885 Views
  • B
    B
    bipedbear
    anyone?
      not much you can do for pliability, besides making relief cuts and reglassing.
      • G
        G
        green6767
        you can warm it up. I know when you mix the resin/hardener together, it gets warm and its easily bendable. Try heating it up, it will smell bad and probably be alittle messy, but I may work. Other than that, relief cuts and reglass as mentioned before.
        08 WRX Hatch
        • darkelvisD
          darkelvisD
          darkelvis
          I definately wouldn't try heating it up. Just my .02.
            Only problem with heating it is that you are weakening the material. Yes, as it is curing it warms up, but you can't really uncure/re-cure something. Think about it like this analogy:
            If you make deer jerky (or beef jerky, whatever) you cure it by adding seasonings and salt, now while it is possible to resoak the jerky in water to remove the added flavors, no matter what you do it won't be the same as the raw meat and you'll never get it back to the jerky flavor it was before...even if you re-cure it. (bad analogy, I know, but I think you know what I'm getting at here)
            • fallguyF
              fallguyF
              fallguy
              I'm hungry for some jerky now!
              1990 Ford Probe GT 2jz RWD
              • G
                G
                green6767
                ok
                08 WRX Hatch
                • 24valvenotak2
                  24valvenotak2
                  • 24valvenotak2
                    24valvenotak2
                    • B
                      B
                      bipedbear
                      ah, yeah i see how i can make some slight releif cuts in my panels, thanks
