Plane on a conveyor belt
tjamz wrote:
you guys are looking at this all wrong. Airplanes do not accelerate using their wheels, they are used as a way to reduce friction (as opposed to dragging the belly of the plane) with the ground until the airplane has reached the speed in which it will lift. The planes jet engines/propellers/whatever provide forward thrust to get the plane to the speed at which it will build lift. The airplane doesn't care how fast its WHEELS are being driven in the other direction, just how fast the plane itself is moving. If the plane is traveling 100mph in one direction and the conveyor belt is traveling 100mph the other direction, the only thing affected are the wheels and the wheel bearings (which would be spinning at 200mph) and a tiny amount of friction. As soon as the airplane built enough thrust to counter the gravity/friction holding the plane to the conveyor belt it would start moving forward regardless of what speed the conveyor belt is moving. In other words you guys are reading the question wrong. If the question stated could a stationary airplane generate lift while not moving you would be correct, however the question asks what happens if it is placed on a belt that is moving the opposite direction of the plane at the same pace as the plane. Again, see my sidecar analogy that I posted earlier in this thread. Exact same principal....screw it, I'll post it again:Think about it this way if you are driving a motorcycle with a side car on it at 50MPH and the conveyor is ONLY on the side car you can still drive the motorcycle at 50MPH, however the sidecars wheel(s) will be traveling 100MPH. Same principal applies here. The planes motors providing thrust would be the motorcycle in above analogy and the planes wheels would be the side car. It is very possible for the plane to take off.*
By your guys theory, the motorcycle in the above situation is not capable of moving forward either.
No, you didn't listen to me. Jet engines (as they are mounted on jet planes) do NOT produce downward thrust. They aren't aimed downward.
You are making the assumption that it's the speed of the plane making it take off, and this is incorrect. Speed is all relative. When you are walking inside a moving train with it, you aren't going at 60 miles per hour. You're going at a meter a second. Same with the plane analogy. The wheels are moving, but the plane relative to its position is not. Regardless, speed does not make the plane fly.
The assumption here is that the conveyor is moving at the SAME speed as the plane, and thus a positive vector (the plane) added to a negative vector (the belt) equals zero. If the belt is moving slightly slower than the plane, then there is some positive movement here, and the plane MAY just move due to the wind that is passing under its wings.
With that said, a large gust of natural wind, as postulated earlier, may be enough to pick the plane up. Sort of like a paper plane. You need air velocity running through those wings, too, if you want it to fly.
AcesHigh wrote:
No, you didn't listen to me. Jet engines (as they are mounted on jet planes) do NOT produce downward thrust. They aren't aimed downward.You are making the assumption that it's the speed of the plane making it take off, and this is incorrect. Speed is all relative. When you are walking inside a moving train with it, you aren't going at 60 miles per hour. You're going at a meter a second. Same with the plane analogy. The wheels are moving, but the plane relative to its position is not. Regardless, speed does not make the plane fly.
I never ONCE said that the thrust was towards the ground (except harrier). I know that speed itself does not make it fly necessarily, but rather the amount of airflow at the wings. What you fail to see is that the wheels do not push the plane forward, they just provide a rolling surface. The plane does not care what speed the wheels are rolling/freewheeling as long as there is thrust moving the plane forward it will take off.
AcesHigh wrote:
Plane wings create lift because air below is moving quicker than air above the wing (and according to physics faster air = lower pressure!). Mix a high and low pressure gradient, and bingo you have lift.^this is what I thought
[QUOTE=dubbsy]Mitch, if I"m reading this right...everything about it is wrong...
#1. Air travels faster over the tops of wings.. This creates a low pressure that in turns sucks the wing up (bring the plane up with it)
#2. The plane DOES have to physically move. /QUOTE]
^this is where my confusion came from...
apparently he is right about the air moving more quickly over the top of the wing creating lift... now I am confused how making the air move more quickly over the top of a car will not have the same effect?
My apologies upon rereading my statement I notice I have it backwards. Air is moving FASTER above the wing (more distance). Also to add to your question of the effect on a car; the effect is the same. We are trying to reverse the effect (greater air velocity on top, lower on the bottom) and hence the ugly aluminum wings you see are trying to "flatten out" the top of the car so to speak.
AcesHigh wrote:
My apologies upon rereading my statement I notice I have it backwards.correct. the bottom of the wing is flat (outside of the flaps of course) while the top of the wing is curved. Air over the top of the wing moves faster -> lower pressure -> wing tries to travel to the area of the lowest pressure and therefore the plane takes off...
The number one key here that people need to realize is..
** NO MATTER WHAT, the plane's relative position will change. It WILL move forward**
dubbsy wrote:
** NO MATTER WHAT, the plane's relative position will change. It WILL move forward**No, it wouldn't. I just want to compile everything I've said so far here:
This scenario is based on several assumptions.
#1. That the conveyor belt is in equi-velocity with the plane and that it's continuously variable. That is no matter how much thrust the plane can create, the conveyor belt is able to match its speed.
#2. The wheels are not neutral. Plane wheels are not free moving wheels that can readily move back and forth. They have gearing, and they function like car wheels (thrust is NOT moving the plane as it's moving towards a terminal, for instance, it has its own motor). Thus if you run an infinitely fast belt underneath a plane it would not just sit still with its wheels spinning; it would go the with the belt in the other direction.
#3. There is no wind besides that which is create upon movement.
And with these assumptions we have:
Jet engines are pointed backwards so downward thrust is nill. Notice that rockets point down...
Air pressure gradients is what makes a wing fly. Higher pressure at the bottom from lower speeds, lower pressure at the top from higher speeds (from greater distance).
Using simple vector addition a positive vector (the plane with thrust) added to an equally opposite vector (the belt) equals zero.
The plane will NOT move or take off. The amount of thrust being released is equal to the speed at which the belt is moving. If you fire a bullet and somehow can blast enough air the opposite way the bullet will stop in place. Equal and opposite vector addition.
Now for TT's car question, the overall shape of a typical car is very much like the wing of a plane. We have rounded tops with flattened bottoms for the most part. If you want to travel at +100mph all the time it is ideal to do the opposite -- rounded bottom and flattened top. Remember that more distance => greater velocity => lower pressure. You want the high pressure area (lower velocity) to be at the top to push you down, and wings do that.
AcesHigh wrote:
No, it wouldn't. I just want to compile everything I've said so far here:This scenario is based on several assumptions.
yes, it will..
#1. Yes.. I will not argue that the conveyor will match the speed of the plane. it's matching the speed of the plane thoug, NOT THE SPEED OF THE WHEELS!
#2. Umm... I don't agree there. Without doing some more research (although everything I've seen thus far agrees), the wheels do no driving of the plane. Hence the use of tow vehicles. Prop planes do not use wheel power on the ground, and this scenario will apply the exact same to a prop plane.. besides, if landing gear was geared it'd destroy everything when it touched down.
#3. No, there is no wind.. However like I've said, the plane will move forward in relative space creating lift.
my god, every time someone posts this I want to bash my head into the desk!If the plane is not moving, then it's speed is zero!!!!!!! Therefore the conveyor is not moving either!!!!
Equal opposite blah blah blah.. The AIR that the engines are acting against is NOT MOVING! Therefore there is no opposite force!
And the wheels are free to roll (I still disagree with the gearing stuff)....meh...
"I watched and listened to the disagreement for a while and was fascinated to see that the argument seemed to split between those who had some engineering or math background, all of whom said the airplane would takeoff and fly without any problem; and those with some other background, who visualized the airplane as having to push against the conveyor in order to gain speed. Because the conveyor equaled the airplane's push against the conveyor, the airplane stayed in one place over the ground and in the calm air could not get any airspeed and fly.
It was an interesting argument, but as things progressed, more rational heads prevailed, pointing out that the airplanes do not apply their thrust via their wheels, so the conveyor belt is irrelevant to whether the airplane will takeoff. One guy even got one of those rubber band powered wood and plastic airplane that sell for about a buck, put it on the treadmill someone foolishly donated to the Lounge years ago, thinking that pilots might actually exercise. He wound up the rubber band, set the treadmill to be level, and at its highest speed. Then he simultaneously set the airplane on the treadmill and let the prop start to turn. It took off without moving the slightest bit backwards."
http://videos.streetfire.net/player.aspx?fileid=35E964D9-38DB-4EFD-BE8D-D6BA1A43A06B
Try looking at it another way. Lets pretend a jet plane is flying at 200mph and comes in for a touch-n-go. It does it's touch-n-go on this hypothetical conveyor that is moving 200mph in the opposite direction. When the jet touches down it will not cease to move forward. Instead the wheels of the jet will be moving roughtly 400mph. If the jet touched down on a normal runway then the wheels would be moving at 200mph. According to the "no fly" people, as soon as the jet touched the moving conveyor it would simply stop moving.
What's up for debate is how the wheels affect the plane when they are on the conveyor.
Nope, no debate.
Let me try this another way.
First, image you have a conveyor belt moving at -1 mph.
Next, put a free standing wheel on it spinning at 2 mph. Nothing is wrong with this so far.
The wheel would be moving relative to the air around it at 1 mph opposite the conveyor.
Just attach a plane to the wheel and you're good to go.
The thrust of the plane now accelerates it to 5 mph. The conveyor now is moving at -5 mph.
The wheels are forced to speed up to 10 mph. Once again everything is fine.
Go back to just the conveyor, spinning at -5 mph. You can put a wheel on it spinning at 10 mph no problem right? The wheel would be moving along the conveyor at a relative speed to the air at 5 mph. Just have a plane sitting on top of the wheels, and once again you've got no problem, the plane is moving at 5 mph as well.
As far as the body of the plane is concerned, the conveyor doesn't even exist.
I already mentioned earlier that speed is inconsequential for a plane to fly. Relatively speaking the plane has a speed of zero because its position has not changed. But there are vector quantities being added here.
What you are basically trying to get at here is that if the plane's wheels are in free motion, then its position is independent of the belt. This is fallacious. When you hop on a moving train, you follow the train. You can't jump up and expect to land on a different traincar. It is NOT independent.
This is what Einstein realized in his theory of relativity, that everything is relative to everything else. We are on a planet that is rotating thousands of miles per hours yet we do not feel a thing. When I hop up into the air, I do not land in New York. If I had wheels attached to me (likewise on the train scenario) I do not stay in one place in space -- I move with the earth.
The plane moves with the conveyor belt regardless if it had wheels or if it "hopped".
The people in your post examples have not taken a class in physics.
This is not a matter of mathematics, or engineering. It's basic physics.
AcesHigh wrote:
What you are basically trying to get at here is that if the plane's wheels are in free motion, then its position is independent of the belt. This is fallacious. When you hop on a moving train, you follow the train. You can't jump up and expect to land on a different traincar. It is NOT independent.you're talking in 2 totally different directions here..
the planes position IS indepentant of the belt.... (now this isn't TOTALLY true due to the small amount of friction in the bearings, however it will be overcome)..
you're train analogy... you're already have momentum and you continue that momentum. Cause if we want to quote famous dead guys, look at Newton - "An object at rest remains at rest, and an object in motion remains in constant motion, unless acted on by an outside force." If you took a hollowed out train with no ends (to eliminate air resistance)... The train is stopped. You jump and while you're in the air the train moves. When you land you will not be in the same position.. This is because you are not independant of the train and did not already have momentum in either direction. If you're still standing on the ground when the train moves, you are not independant of the train anymore..
with the plane, the wheels make the plane independant of the conveyor (again this is ruling out the small bit of friction that is easily overcome)
How about this.. put the plane on a stopped conveyor and then have the conveyor instantly jump to 50mph. Will the plane stay in the exact same spot on the conveyor belt? NO! Yes it will move backwards some (again because of the easily overcomable friction...hell, it has to be overcome for a plane to fly in the first place!) however it will stay much closer to it's relative position than to it's original spot on the conveyor.
now I also want to hit another angle...
like I've said, no matter what (once again, once the small bit of friction is overcome)... if the plane and conveyor are moving the same speeds then the plane HAS to be moving forward...
now is it possible for the conveyor to keep the plane in the same relative spot? yes....(most likely). To do this the conveyor would have to be turning at extreme speeds to multiply the drag in the wheel bearings enough to overcome the thrust of the engines...
however in the case, the conveyor would be turning very very fast, the plane wheels would be spinning at the same speed, however the PLANE WOULD HAVE A SPEED OF ZERO! -
In the first example with the toy plane and the treadmill, the plane flew because its vector was greater than the treadmill's. There was a positive net vector and thus it moved.
In the second quote, imagine a plane moving at 400mph. Now put a giant conveyor belt underneath it at 400mph. What happens? Relative to the belt, its speed is ZERO. Another simple vector addition. The earth is still moving at 400mph underneath the belt, but in terms of relativity the plane's movement is zero. Another plane flying parallel to the first plane will note that they aren't moving (provided they cannot see the clouds or the earth) even though they are in space!
I don't even want to read the third one, but I assume it's the same as the last two.
Again, what this all boils down to is relativity and vector addition. We as humans see things relative to other things. We see light as being fast because relative to us, it is fast. If someone were to move at the speed of light, normal humans would look like we were frozen in time.
I just want to make another quick comment here before I go..
We are not arguing if the the plane has a speed of zero because I already said that it did. Hopping inside a hollowed out train would still do the same thing as the hopping on top of the train.
Here is one last analogy to help everybody understand:
If you were on a train and running as fast you can the opposite way as the train, which is going as fast as you are. Provided you can run forever, you are running towards a overpass bridge which is 10 meters ahead of you. There are infinitely many train cars.
You are at a stationary 10 meters from the bridge. If you jump while running, you remain in the same place. Unless you increase your speed GREATER than the train, you will not move. Given the plane scenario that the belt is continuously variable, if we apply it to this scenario we find that if we run faster the train will go faster the opposite way and --- vector addition, zero displacement. You are still 10 meters away from the bridge no matter how much you run, jump, whatever.
Wheel speed does not matter, it is the overall plane speed that does. If the wheel speed is less than the conveyor belt speed (using vector addition one last time) we have a negative displacement which means the plane will move backwards infinitely many times.
Have a good night you guys.
Here's my theory...
Think of a Kite; a kite can lift off w/o moving forward; I think the thrust of the engine will pull the air over/under the wings, and therefore it would take off.. I could be wrong, just an analogy...Oh and if it was a propellered plaine, Propellers in front of the wing; wouldn't that create air flow over/under the wing as well?
depends on what type of plane we're talking about too I guess.. -
Aceshigh, you are incorrect that planes using gearing in the wheels for take off, they entirely use their jet engines for this, how else do you think they accelerate so damn fast down the runway? You keep looking at this from the point of view that the plane is not moving which is not true, it may not be moving as fast with x amount of thrust when y amount of conveyor movement is pushing the opposite direction, but it is moving at will once it generates enough forward thrust to start the wheels spinning.
Your last analogy again assumes that the airplane is using its wheels to generate enough speed (approx 150mph I am told is what it takes to get an airliner airborn) to take flight which is fundamentally what is flawing your analogies. The wheels on a jet are free rolling units (at least on take off and landing) whose only purpose is for minor steering correction and to allow the plane to easily roll when thrust is applied. As soon as you realize that fact you will realize that it is possible for the plane to move forward while on a conveyor belt.
