  4. Battery relocation
Battery relocation
11 Posts 8 Posters 977 Views
    pin
    This page can be a starting point if you need a general idea of what you'll need. If you want to pass tech inspection at an NHRA track, you'll need an approved battery box and a remote disconnect switch. Summit Racing would have those things, as well as Performance Auto and I'm sure other performance shops in town could order them if they don't normally stock them. The blue Moroso battery box is one that comes to mind, and I think it costs around $80. You can't get away with a marine battery box as they aren't track legal. Someone else more knowledgable on this subject will probably correct me on some things.
    Barry
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      Pin nailed it right on the head. As far as the legality, sabin lets a shitty marine box pass tech, but I don't think any other tracks near here will.
        ya don't know if i want to spend lite 200 on a tiny battery and also have to make a mounting kit for it, but at same time don't want a whole with a switch on back bumper..
          pin
          If you don't need the extra space under the hood then don't bother relocating the battery to the rear of the vehicle. I'm going to be needing the extra room, so I've recently looked into this matter again. I'm willing to cut up the body to mount a disconnect switch as I drive a 13-year-old car with shit for resale value.
          Barry
            The switch part sucks, but there are plenty of ways to make it look good. One thing you could do is modify an extra taillight for the track. I've seen some of the SN95 mustang guys do that, and it looks pretty good. You can then put the other light in for the street and not have a big switch sitting there.
              hes gonna need the extra space...i guarantee it...my car is mostly stock and i dont even know how id be able to work in the engine bay without the battery in the trunk...if you are worried about the switch just have a way to disconnect it or somethin...i know kevin had some worries about that and he found a way around it or somethin
                its either tiny tiny battery in some place, relocate or about 1 inch cold pipe and i think i'll take 1 off the first 2 but i am waiting tell motor make a new apperance in car agian to figure it out just looking for info now sense i got nothing better to do besides work everyweek end i just run into dead end after the motor bay is painted i have everything else almost done a.k.a. repaint of all brakets and stuff cleaned and nothing else can really be done, just waiting for clutch and motor mounts and then get motor in and see how it runs and then have fun with turbo stuff
                s13 are so more owner/worker friendly 😄
                • fallguyF Offline
                  fallguyF Offline
                  fallguy
                  Make sure to do the switch properly if you are running the alternator still. You'll need to run a wire from the alternator to the positive on the battery then to the positive battery to switch, then from other side of switch up to the fuse distribution block. Most race cars don't usually run an alternator so it's really easy to do it vs wiring it with an alternator.
                  Good luck!!
                  Here is a link that I used. http://www.supraforums.com/forum/showthread.php?t=247941&page=2&pp=25&highlight=battery+switch+wiring
                  1990 Ford Probe GT 2jz RWD
                  • XJHEADX Offline
                    XJHEADX Offline
                    Good luck!!
                    Can't use link, and I am surely not going to register there.
                      good detail matt. I can help you with it jon. I did it on the probe already once. Pin, His car is RWD, its not just to say he has a battery in his trunk. He needs space under the hood and as much weight as he can get over the back wheels.
