Painting the CRX
That JDM ITR dark red is pretty nice.
Is it actually called JDM ITR dark red or what is the real name? I want to paint the hatch that color after motor
Thanks for the input, I like the bright red one that lank posted better. I am not very fond of the dark reds. I am going to United Automotive in the morning to look at paint samples and try to pick a color. I am trying to do this paint job on a budget so I may go with the Omni pant too, unless the PPG isn't much more. I also need to pick up some body filler, but otherwise the car is going good.
Only a few minor dents, I found about 10 bondo sport where the previous owner started fixing the dents. I was supprised to fin the car relitively rust free other than 3 baseball sized spots on the driver door, grinded them down and will fil them later, it was just minor surface rust.
Also I bused most of the clips that hold the ground effect moldings on, so I hope I can find new ones.
Here's a pic of tinights progress, 5 hours of sanding and the driver side is mostly done.
Ok, I went and picked out colors, its between these 2 reds. Corvette Torch Red or Ferrari Rosso Red.
Go with the ferrari red
Both of those reds will look really good.
viper red
or HOK oriental blue over silver
Tonights Update. I am about 70% done with the body work and sanding. I had a handful of dents to fix and found some rust holes under the trim I had to weld new sheet metal in, Otherwise its comming good, almost got the body itself done, but haven't even starter on the bumper covers or trim yet. Still hoping to have primer shot this sunday and paint laid before next weekend. Its gunna be a fairly nice car. Now only if I can complete the interior, I would be set.
I ordered a set of Neuspeed Lowing spring and hope to have new wheels ordered next month.
Mike
update, the car is in primer. Going to be painted this weekend. Body isn't perfect but it is nice enough for a daily driver.
Whats with the runs on the front bumper??
I forgot to take the picture before I started sanding. I had already wet sanded the front clip.
