  4. DSM stuff
DSM stuff
77 Posts 20 Posters 4.8k Views
    Don't worry about it Scott, this guy has something against all of you guys or something...
    • BomexEB Offline
      BomexEB Offline
      BomexE
        Scott, yes $150 will work for the cage. And can someone clean up those couple posts that don't belong? Thanks.
        • BomexEB Offline
          BomexEB Offline
          BomexE
          sweet well i will be getting a hold of you in the future this winter, i gotta fix a couple things with my car first, but yeah i will more than likely buy it from you, but if someone else offers to buy it before i get ahold of you, go ahead and sell it, no hard feelings
            Alrighty man, just let me know when you want it.
              Here's pics of most of what's left:
              95-96 transfer case.
              Autometer 2 pod gauge bezel
              Non turbo throttle body
              Electric oil temp gauge
              S&W Racecars 8 point roll bar for a 2G DSM.
              Shepherd brand new OEM tranny with their "Race" parts installed, Shep transfer case is sold.
              Volk TE 37 wheels
              Switzer coil on plug ignition
              And also a few other random things I found too which are for DSMs, just some more random stuff:
              1G CAS $20
              1G 93-94 style CAS $20
              2" 90 degree elbow made of steel, powdercoated silver $5
              Aluminum plate for making your own coil on plug ignition for a 4G63 $30
              Semi polished heat shield $5
              A bunch of misc. gaskets and other parts for a 4G63, some of the parts included are: new throwout bearing, 4 brand new 3G style lifters, new Mitsu composite head gasket, valvecover gasket set minus 2 spark plug hole gaskets, front case gasket, transfer case output shaft seal, some other misc seals, 4 turbo oil return line gaskets, and also not in the pic is a 2G knock sensor. $50 takes all of it.
                will you take 300 for the 97-00 t-case?
                • JohnWJ Offline
                  JohnWJ Offline
                  JohnW
                  ill take the used K&N filter for $10, PM sent.
                  90 Civic DX hatch
                  D16a6/y8 mini me
                    Replied to both of you.
                      supa_dupa_man
                      How much for the JIC Magic FLT-A2 suspension? and is it a 4"?
                      SUPERMAN!
                      96 eclipse (base model) 11.27 @ 127mph
                      97 eclipse gst
                      97 integra ls
                      98 cbr 600 stunt bike
                        I have a pending payment through PayPal for the suspension. Is what a 4"??
                          supa_dupa_man
                          Is the suspension 4" adjustable? most DSM coilovers are 3" adjustable.
                          SUPERMAN!
                          97 eclipse gst
                          97 integra ls
                            Suspension is sold.
                              troy i'll take the heat shield and the t-case if you are willing to sell it seperate.
                                Which transfer case?
                                  97-99
                                    60mm 1G NT throttle body 40
                                    ADFX Racing FMIC 24"x10"x3" w/ 2.5" aluminum piping up to the 3" GM MAF, and then a 3" 90 degree elbow from there to the throttle body. You will need to have your battery relocated to use this setup, comes with all couplers, you supply your own MAF, flanged for HKS Super Sequential BOV, $500
                                    Optima Yellow Top battery (full size) 100
                                    Body Styling
                                    LP Performance ABS front lip 75
                                    Interior
                                    S&W 8 point roll cage 150 WILL NOT SHIP
                                    Blue LED shift light 10
                                    Autometer 2 pod Gauge Bezel 40
                                    Autometer Phantom Oil Temp gauge 40
                                    Misc.
                                    Shepherd "Race" transmission, this is a brand new OEM tranny, taken apart and built to Jon Shepherd specs, details are listed on their website, I also had them put in their own cast chromoly shift forks which were extra, this thing shifts amazingly well, and only has about 1000 miles on it. $2200
                                    Switzer coil on plug ignition 200
                                    95 transfer case 200
                                    All this stuff needs to go!!
                                      awd95mn
                                      I want those rims so bad!
                                        will you take $1000 for the wheels?
                                          No way. They should go for a lot more than that on ebay.
