  4. DSM stuff
DSM stuff
77 Posts 20 Posters 4.8k Views
    Alrighty man, just let me know when you want it.
      Here's pics of most of what's left:
      95-96 transfer case.
      Autometer 2 pod gauge bezel
      Non turbo throttle body
      Electric oil temp gauge
      S&W Racecars 8 point roll bar for a 2G DSM.
      Shepherd brand new OEM tranny with their "Race" parts installed, Shep transfer case is sold.
      Volk TE 37 wheels
      Switzer coil on plug ignition
      And also a few other random things I found too which are for DSMs, just some more random stuff:
      1G CAS $20
      1G 93-94 style CAS $20
      2" 90 degree elbow made of steel, powdercoated silver $5
      Aluminum plate for making your own coil on plug ignition for a 4G63 $30
      Semi polished heat shield $5
      A bunch of misc. gaskets and other parts for a 4G63, some of the parts included are: new throwout bearing, 4 brand new 3G style lifters, new Mitsu composite head gasket, valvecover gasket set minus 2 spark plug hole gaskets, front case gasket, transfer case output shaft seal, some other misc seals, 4 turbo oil return line gaskets, and also not in the pic is a 2G knock sensor. $50 takes all of it.
        will you take 300 for the 97-00 t-case?
        • JohnWJ Offline
          JohnWJ Offline
          JohnW
          ill take the used K&N filter for $10, PM sent.
          90 Civic DX hatch
          D16a6/y8 mini me
            Replied to both of you.
              supa_dupa_man
              How much for the JIC Magic FLT-A2 suspension? and is it a 4"?
              SUPERMAN!
              96 eclipse (base model) 11.27 @ 127mph
              97 eclipse gst
              97 integra ls
              98 cbr 600 stunt bike
                I have a pending payment through PayPal for the suspension. Is what a 4"??
                  supa_dupa_man
                  Is the suspension 4" adjustable? most DSM coilovers are 3" adjustable.
                  SUPERMAN!
                  97 eclipse gst
                  97 integra ls
                    Suspension is sold.
                      troy i'll take the heat shield and the t-case if you are willing to sell it seperate.
                        Which transfer case?
                          97-99
                            60mm 1G NT throttle body 40
                            ADFX Racing FMIC 24"x10"x3" w/ 2.5" aluminum piping up to the 3" GM MAF, and then a 3" 90 degree elbow from there to the throttle body. You will need to have your battery relocated to use this setup, comes with all couplers, you supply your own MAF, flanged for HKS Super Sequential BOV, $500
                            Optima Yellow Top battery (full size) 100
                            Body Styling
                            LP Performance ABS front lip 75
                            Interior
                            S&W 8 point roll cage 150 WILL NOT SHIP
                            Blue LED shift light 10
                            Autometer 2 pod Gauge Bezel 40
                            Autometer Phantom Oil Temp gauge 40
                            Misc.
                            Shepherd "Race" transmission, this is a brand new OEM tranny, taken apart and built to Jon Shepherd specs, details are listed on their website, I also had them put in their own cast chromoly shift forks which were extra, this thing shifts amazingly well, and only has about 1000 miles on it. $2200
                            Switzer coil on plug ignition 200
                            95 transfer case 200
                            All this stuff needs to go!!
                              awd95mn
                              I want those rims so bad!
                                will you take $1000 for the wheels?
                                  No way. They should go for a lot more than that on ebay.
                                    Wheels are sold tonight.
                                    • RudeAwakening MotorsportsR Offline
                                      Would you take 100 for the roll cage? Also is it a bolt in or will welding be involved?
                                      =Jason-
                                      ---->Always One Step Ahead
                                        It's a weld in cage.
                                          =Jason-
                                          Bring me a $100 bill and come get it. It's a legal cage made by S&W Racecars.
