  3. ICE and Detailing
  4. Livin Loud
Livin Loud
31 Posts 10 Posters 7.6k Views
  • the66T
    the66T
    the66
    I currently have a 97 gmc ext cab with 4 12" kicker comp cvr's, kx850.2, dual battery, 220amp alt, kx300.2 for highs,kicker 6.5 compenent series speakers, kicker4x6's in rear, completely dynomated interior
    • 2slo50h2
      2slo50h2
      2slo50h
      Well welcome. Anymore plans for the GMC?
      • wesholeW
        wesholeW
        How about some pics of the install?
        • RidinRailsR
          RidinRailsR
          get some pics of the install.
          i know a guy who had 2 L7's in his s10 with a ported box and it blew his back window out.
          • camzaro28C
            camzaro28C
            camzaro28
            ^^^^^^ must not have been put in to well
            jig 4 prez
            • the66T
              the66T
              the66
              i will try to get some install pics soon.... i have new plans for the truck.... back seat is gonna be romoved and building fibergalss enclosure
              • RidinRailsR
                RidinRailsR
                yeah it was a shittier sliding back window...plus the enclosure the subs was in was a great design
                • the66T
                  the66T
                  the66
                  now ordering a second kx850.2 and second altenator, hopeing to clear 155 db.... no more like 160db its gonna be a good time since it already hit 148.7with out being tuned for contest
                  • RidinRailsR
                    RidinRailsR
                    ^^^prove it!!!^^^
                    4 vr's will never hit 160.
                    and you will never need 2 altrenators for 4 vr's.
                    I just installed 4 13.5 inch JL audio w7's in a tahoe with 4 1000 watt JL audio amps, 4 caps, 4 batteries and 1 big ass alt, and his lights dont dim a bit.
                    • krzydrftr93K
                      krzydrftr93K
                      krzydrftr93
                      97slowgsx wrote:
                      ^^^prove it!!!^^^
                      13.5....O there square arent they.
                      That sounds like a kick A$$ system.
                      Matt
                      92 Civic HB
                      JDM d15b w/14b@8psi
                      • HandoEXH
                        HandoEXH
                        No, they are not square.
                          Raising the BS flag here, I've seen quite a few competition vehicles hit 150-160 dB and while the windows (OEM..not reinforced) were flexing, they never "Blew out"....I'm sure Wes can probably remember Mark Fukuda's yellow RF Blazer, it was the worlds loudest vehicle for quite a while, well he ran factory glass up to 160decibels. Unless by blew out you mean loosened the seals, that can/does/will happen on a high SPL vehicle and I suppose if the seals were bad long enough it could fall out.
                          • wesholeW
                            wesholeW
                            Ya, I remember thinkin that he wouldn't hold the record for as long as he did. I have never seen (in all my years in the car audio) glass "blow out". But as Chuck said, I have seen back windows of pickups push the seal out. But the lowest I've seen that at was 169db.
                            • wesholeW
                              wesholeW
                              Wait a minute, I have seen a back window "break" from the car stereo. But it was because the rear glass of the S10 Blazer was rattling around from the bass and it shattered starting where the striker met the glass. Oh and I've seen a couple of other times when windows have been broke as a result of car stereos. That was from when they were stolen and they broke the glass. haha.
                                No argument from me on anything wes posted above^
                                • camzaro28C
                                  camzaro28C
                                  camzaro28
                                  ^ i am with u guys on the window didnt blow out, as i said earlier.
                                  hey chuck remember us having a convo about me hitting 154 db? with only one sub? well i found the slip 😄 i will post it if u like
                                  jig 4 prez
                                    alway curious to see it.
                                    • wesholeW
                                      wesholeW
                                      I seen 148 on a single 8" solo. That impressed me all to hell.
                                        a/b/no weighting scale? Also was it to USAC/IASCA spec (no frequencies above 80Hz measured). I know the old "trick" used to be to use upper harmonics (think midbass/midrange frequencies) to spike the mics
                                        • camzaro28C
                                          camzaro28C
                                          camzaro28
                                          the meter was under the passenger dash in my other camaro.
                                          1 15' W3 wired to 1 ohm IIRC on a reworked mmats amp
                                          edit: not sure if the above ? was directed to wes or me, but IIRC that box adn sub would hit peak @38db. and USAC
                                          jig 4 prez
