  4. t-25 problems....
t-25 problems....
10 Posts 8 Posters 591 Views
    burnteclipse
    my friend just installed a t-25 on his car and he cannot get it to boost. we cant figure it out, it has no shaft play or anything just will not boost. what could be the problem? Application is a talon tsi. Thanks
      make sure the wastegate isnt stuck open...
        Wastegate stuck open will usually still spool 5 psi just really laggy. Sure its not seizing up?
          Is the turbine spinning for sure?? Check all of your piping too obviously but even with a decent leak it should still create some boost.
            yeah and if its not building any boost and its leaking out with a pull through maf it'll feel just dandy too...
              If you have that big of a boost leak on a DSM you'd know it, it'd be running like ass, super rich, no power.
                Time for a new turbo... and the modding starts!
                  And breaking.
                  • krzydrftr93K Offline
                    krzydrftr93
                    weshole wrote:
                    And breaking.
                    Its a DSM...they break no mater what 😄
                    Atleast mine did...
                    Matt
                    92 Civic HB
                    JDM d15b w/14b@8psi
                      aliengotpsi
                      smoking? exhaust leak ? did the turbo fall off? boost leak? does he get any boost? like 5-6?
                      I got a great idea step up to the table and buy ur self a S200 switzer along with all the supporting mods...
                      Kevin Smith
                      Straightlinedetailing.com
