  4. Fuel line question
Fuel line question
19 Posts 6 Posters 1.5k Views
  • XJHEADX Offline
    XJHEADX Offline
    What is the biggest AN-XX fitting end can I get with a 3/4" ORB on the other side??
      I'm not sure what ORB is?
      -12 AN is 3/4" ID if that helps.
      • D Offline
        D Offline
        dynotune
        geez dave, yer dumb. An ORB is what the genie looks into to see your future.
        Psshhttt.... ROOKIES.
        DynoTune Speed & Performance
        Mobile chassis dyno service
        www.dynotuneusa.com
        (605) 753-1101
        • D Offline
          D Offline
          dynotune
          www.summitracing.com
          MEZ-WP12034B
          maybe what you need??
          www.dynotuneusa.com
          (605) 753-1101
          • D Offline
            D Offline
            dynotune
            They have 90s and stuff, too- but nothing over 3/4 that I can find. Why are you working on your outdoor sprinkler system this time of year??? 😉
            www.dynotuneusa.com
            (605) 753-1101
            • XJHEADX Offline
              XJHEADX Offline
              O-Ring Boss, I guess that is old school
              It is not for the sprinkler system this time. 😉
              By the way thanx FARGOSTREET for the help
              EAR-985012ERL $17.88
              Estimated Ship Date: Monday
              Brand: Earl's Performance Plumbing
              Product Line: Earl's Performance AN Port Adapters
              Fitting Attachment 1: Male threads
              Fitting Size 1: -12 AN
              Fitting Attachment 2: Male threads
              Fitting Size 2: -12 AN O-ring
              Fitting Angle: Straight
              Fitting Finish: Blue anodized
              Fitting Material: Aluminum
              O-Ring Material: Rubber
              Quantity: Sold individually.
              Fitting, Straight, Male -12 AN to Straight Cut Male -12 AN O-Ring, Aluminum, Blue, Each
              Special purpose adapters.
              Earl's Performance special purpose adapters are manufactured from an aluminum alloy which meets and exceeds the minimum requirements for aerospace fittings. They're precision-machined to exacting tolerances for trouble-free and long lasting performance, and feature a contoured port end for maximum flow.
              Back to Search Results
                no prob.
                  Sounds to me like a sprinkler system of some sort is being plumbed hahaha.
                  • XJHEADX Offline
                    XJHEADX Offline
                    Another thing I am going to be looking for is larger sprinkler heads, I need alot more liquid for this new application..
                    This is running off a well that pumps 840#/hour @60 psi. Most of you guys would tell me 4-6 heads would be enough but I say fuck-it lets do it with 8
                      I think andy probably has some ball valves that would work....
                      "on ..... offf ..... on ... off" oh fuck out of gas.
                      • XJHEADX Offline
                        XJHEADX Offline
                        I may have to check with him on that. Thing is, I will need some sort of inj. driver for that route and I do not think Andy will fit under the hood very well.
                          He's kindof skinny though. Just get a bigger cowl.
                          • XJHEADX Offline
                            XJHEADX Offline
                            How about a head scoop
                            • XJHEADX Offline
                              XJHEADX Offline
                              I guess the -10 feed line is not big enough. Need some new -12 line from the pump to the rails.
                              Dave, thanx for pulling your pump to try, but it still did the same. We set the base fuel pressure to 90 psi, and it still dropped off, left the boost reference line off. I need about 12+ inches per side for rails. I am going to cut off my existing fittings and have some -12's welded on, mine are just over 5/8". Got into Fargo at about 2:30 AM 😞
                              • XJHEADX Offline
                                XJHEADX Offline
                                Guess we are going to try Dave's and my pump together. We'll see
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  Latest update if anyone cares. I had to run Dave's little pump and my little one together. I had to run another -10 feed line to the front of the motor. A pair of -10 now. We were a little concerned about dead heading the pumps through a single regulator with -8 to the tank. Anyways the lowest we could get the fuel pressure to was 80-85 pounds. We then set it up for mine to run at idle and the second to come on right before the pull on the dyno. That didn't work so well, wanted to load up on too much fuel. Anyways Dave came to the rescue again as he pulled his regulator off late Friday night for me in case it worked better. I thought we were going to have to run two regs. We swapped out to Dave's reg turned on both pumps, 40 lbs. no problem. Set base pressure at 60 and made a few pulls.
                                  Normally at end of pull I see about 150 mph. on the last pull same rpm only saw 115 mph. I wonder what is happening now:3gears: I think we are done don't want to push it any further. Need to clean the car and add some more timing into it for SEMA
                                  • M Offline
                                    M Offline
                                    musthavemuzk
                                    i cannot imagine that much fuel or pressure. bet it is fun as hell to drive though.
                                    Monty
                                    14.59 at 94.85 still stock
                                    www.pbase.com/musthavemuzk
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      Monty
                                      I wouldn't know:mad: Andy won't let me drive my own car
                                      • M Offline
                                        M Offline
                                        musthavemuzk
                                        well that is just wrong. jeez why have a bad ass car you cannot drive?
                                        Monty
