  4. blow off valve
blow off valve
39 Posts 12 Posters 2.1k Views
    whats the coolest sounding bov? and dose any buddy nowhere i can find bov sound clips
    • FlowcusF Offline
      FlowcusF Offline
      Flowcus
      Blow off valves arent meant to be cool sounding their meant for performance.
      I ride random bitches.
        TurbodGermanPat
        my diverter valve (like a BOV except dumps the air back into the intake after the MAF) sounds nifty
          i dont know if i would call them a performance mod there more just to save your turbo a little longer
            The best sounding BOV or the loudest? Turbo XS RFL... but its not made for performance but if you want to pickup those 15 year old girls...
              There is a large difference between BOV's... beside the sound; and yes they do affect performance.
                the best sounding
                  Alot of BOV's sound different... Greddy Type - S can be adjusted to "stutter", Turbo XS RFL have a piercing PSSSHHHT sound. I dunno, I have clips on my other computer, I'll post them tomorrow.
                  Its bad when you go around making BOV noises though.... vrrrooooom psssht. I do.
                    ok cool i just want to get somthing that will surpries people when i drive bye
                      vroooom psht jim? your good at sound effects
                        like do they add hp or what?
                          Any vented BOV will be loud... and surprising to people.
                            They can leak, and when they leak you loose HP
                              Thanks. Whatever you know you make car noises too...
                                i try making 97 GS-T spyda noises, but their to far behind so i can't hear them.
                                  Wait, The STi is so quiet you can never hear it... so that sound you think is your car... must be mine ahead of yours...
                                    it is? when
                                      PLEASE don't EVER buy a TurboXS BOV. They are total garbage. Just stick with a Greddy, HKS, Tial or Blitz. If the sounds really matter that much, do a search on some of the DSM forums, someone had a page with a bunch of different sound files and vids of different BOV's.
                                        Yup. They are notorious for being shitty. Recommend: Greddy, HKS, Tial
                                          a bov (various names, diverter valve being one) is designed to relieve pressure between shifts or when the throttle is closed abruptly, thus saving excess wear on the throttle body and the turbo.
                                          they can affect preformance (positively or negatively) by either venting or recirculating. venting is releasing the pressurized air to the atmosphere, and recirculating pushes the air back in (generally) behind the mas (mass air sensor) to help keep the turbo from losing momentum between shifts.
                                          if you're really hung up on the sound of your bov, don't bother boosting your engine, you more than likely won't be able to hear much more than a pah (yes, pah with a very quiet "p") inside the car. in addition, if you just want to suprise people with a weird sound your car makes... pull it out of gear and then slam it back into gear without the touching the clutch or the gas pedal.
