  4. Turbo Manifolds - Finished Product
29 Posts 15 Posters 1.5k Views
    i am trying to locate an exhaust manifold gasket...when i get one ill bring it on over
      pin
      Do you ever wire brush that discoloration off the welds?
      Barry
        Um, no. Coloration indicates a good weld. No reason to remove the coloration when once the car is ran everything will turn a nice color anyways as its stainless steel.
          pin
          What do you think of this? http://www.industrialtool.com/walter-surfox.html
          Barry
            slowvo
            dude...you guys really need to get into making manifolds for volvo's....those guys pay 1500 or so for the cheapest one....
              Looks good, the 4 into 1 collector is cool.
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                Give us your car for a test dummy.
                  i dont know if coloration indicates a good weld...being its that color because of the heat....although the welds do look really good....either way once its on a running car the whole manifold will be that color anyways...
                  pretty nice mani's
                    That looks good but it will all change back as soon as it gets hot. that was designed for use on Stainless that never sees exh temps.
                      Coloration of a weld is good. A weld with zero color or that looks black shows contamination of either material, filler, or the tungsten. Again, color = good.
                        So glad people that have no idea or experience are commenting here, typical!
                        No color indiciates the weld was either welded to hot or has contamination in it. Heat is irrelevant to the coloration.
                          no experience ...hahahaha
                          coloration comes from clean, continuous welds...and if you continuously weld...it gets hot...which forms the color!
                          but what do i know about welding....
                            Soooo...which is it John?
                              did you forget to read the second part of the 2nd quote there Chuck??? ...did you think i was contradicting myself????....because you forgot to read the 2nd part of what i said...
                              Here i will repost it for you....
                              "coloration comes from clean, continuous welds...and if you continuously weld...it gets hot...which forms the color!"
                              if coloration doesnt come from heat....where does it come from??? the metal...no...
                                Ok now kids, that's enough. This is the tech section. Let it stay that way please. Go play rough in the run your mouth section. That's a far bigger play ground.
                                And Nick, they look marvelous.
                                  bad ass!
                                  • fallguyF Offline
                                    fallguyF Offline
                                    fallguy
                                    Looks real nice! I wonder how one of those will look on a certain 2jz powered probe? 🙂
                                    1990 Ford Probe GT 2jz RWD
                                      97slowgsx>
                                      What have you tig welded with all of your experience then?
                                      Just asking...
                                        WHAT? WHO HAS ONE OF THOSE... THAT GUY MUST BE ON CRACK!
                                          Yeah your right wtf do i know. So your saying if i go run a short bead right now w/ little amps its not gonna color?
                                          I guess i found a new employee welder/fabricator i've been looking for!! Feel free to stop in for your hands on interview and if im impressed, you got a job.
