  4. Tube frame...
Tube frame...
18 Posts 13 Posters 997 Views
    aliengotpsi
    --------------- www.swracecars.com------------------
    I have had these parts around for about a year...
    10-400 Frame 24'' 4 Link Fully welded 610.45
    10-400H Hardware Kit
    40-400 Track bar for 10-400 56.65
    40-121 Lazer Link Rod End package 290.00
    40-118f Lazer Link less Rod ends, No frame brakets 151.95
    40-223-95 Shock & spring mount Kit 95# springs 179.95
    36-000 Frame A- Arm Rails Pinto type , rack X- member , shock support 449.95
    36-001 A- arm upper with Hardware 185.75
    36-002 A- Arm Lower With Hardware 239.75
    35-005 Pinto Tie rod end Kit 44.95
    36-006 Rack mount Bushing 19.95
    36-003 (4) ball joint For Pinto Front A-Arm Package 79.80
    36-008L Fabricated Pinto Spindle- Left Side With 4 Piston Braket 199.00
    36-008r Fabricated pinto Spindle Right side with piston Braket 199.00
    35-042 Wilwood Rack & Pinion 239.95
    50-017a Hal Corp Aluminum Coil Over shock 2-1/4 '' Travel single ext . ADJ 359.98
    50-029 Coil Over Spring 250 lbs7x2 1/2 77.00
    12 point cage for a 1g DSM 255.00
    Shipping 350.00
    Also have 27'' DOT slicks, and 15'' rims 250.00
    plus i have a 1g dsm stripped down and close for install
    over 4000.00 invested in to this set-up.. its all brand new and never installed. looking for 3000.00 for all.. I may ebay this all soon..
    I will get pics soon or you can look at it on www.swracecars.com
      aliengotpsi
      bump.
      • N Offline
        N Offline
        Ngige
          aliengotpsi
          • 91nbtsi9 Offline
            91nbtsi9 Offline
                  aliengotpsi
                      slowvo
                      • fallguyF Offline
                        fallguyF Offline
                        fallguy
                          • 9 Offline
                            9 Offline
                            91psiTSI
                              slowvo
                                BUMP
                                  Sorry to say this Kevin, but I highly doubt anyone in the area is going to buy this. That's a huge project to take up. Maybe try the Idrags forum too? If some domestics can use that stuff its worth a shot.
                                    Idrags forum is long gone...
                                      aliengotpsi
                                      I pretty much got a buyer but thanks i think I know what your speaking
