  4. machine shop?
machine shop?
28 Posts 12 Posters 986 Views
    i was wondering where in town would be the best place to get a stage 3 port polish done for my head and a .20 bore?
      What the hell is a stage 3 port and polish?
        hahaha.... that's great... yes, please expand on what kind of port and polish work you're looking for
          and are you sure its a .20 and not a .020 bore?
            Multi Angle Valve Job, Bowl Porting, Gasket Matching Intake Ports, CC Cumbustion Chambers, Extensive Competition Porting And Polish, Assembled and Ready To Install, For Those Looking To Get The Ultimate In Performance , Intake Flow rates 300 + Exhaust Flow 235 +, yeah i meant a .020 bore new to motor build ups so bear w me
              why would you bore your motor unless you have to? just makes the walls thinner...
                i didnt ask your opinion on what im lookn to do i was asking the best shop in town to get such work done
                  What kind of vehicle?
                    a 2.4 out of a stratus/caravan pt crusier motor for a motor swap, just lookn to get the machine work done locally
                      It sounds like the stats you request for machine work were straight out of a magazine ad/article. I find it VERY hard to believe that a person would know sooooo much about what he wants without knowing whom locally, can do the job.
                        exactly why i asked why you were gonna bore it when it just makes the walls thinner...theres a reason people only bore when they have to...
                          you asked what it was so i posted the information that i had avail. to me http://www.southeastperformance.com/ is actually where i got the info from and did i claim to know much about the subject??i think not if u can read you will clearly see that posted,or would it be better to just get the motor sleaved? i believe, and stragiht line spec. is the place to go then?
                            So, is this engine going to be N/A or turbo?
                              a trubo setup is in the motors near future, hahun racecraft btw
                                The reason I ask is because if you are going to boost it, you really wont need to port the head at all. Your head will easily support well over 400 whp w/out porting. same goes for boring the block. Now, if you just want to build it up to withstand the power.... Then that's a different story. But the engine in stock form will easily handle boost. The only thing you have to replace is the weak-ass head gasket with a metal one. The things you are asking for are not really necessary if you plan on boosting it.
                                  i dont plan on boring it unless the walls of the donor motor are in poor conition to the point where i cannt hone it out, and i figured sice im going to completly rebuild the whole motor why not do it right the first time and free up somemore hp instead of changing my mind down the road and having to yank the head out at a later date
                                    Because sometimes you can go overboard on porting and get even less USEABLE power that before porting. It is wise to do the valve job etc. but, I firmly believe that the $$$ spent in doing the full port job is better spent on the real power makers. Case in point, Nick (GSR) who posted on the first page has posted over 500 whp on a non ported head. I don't remember the exact #'s but it was hella big.
                                      Neon motor for applications over 250whp i'd strongly think about building the bottom end for reliability.
                                      • dubbsyD Offline
                                        dubbsyD Offline
                                        not necessarily. 🙂
                                          If the older ones are what is being referred to, then you are right. I may be off a bit but I was thinking of the SRT4 engines.
