  4. machine shop?
machine shop?
28 Posts 12 Posters 1.2k Views
    The reason I ask is because if you are going to boost it, you really wont need to port the head at all. Your head will easily support well over 400 whp w/out porting. same goes for boring the block. Now, if you just want to build it up to withstand the power.... Then that's a different story. But the engine in stock form will easily handle boost. The only thing you have to replace is the weak-ass head gasket with a metal one. The things you are asking for are not really necessary if you plan on boosting it.
      i dont plan on boring it unless the walls of the donor motor are in poor conition to the point where i cannt hone it out, and i figured sice im going to completly rebuild the whole motor why not do it right the first time and free up somemore hp instead of changing my mind down the road and having to yank the head out at a later date
        Because sometimes you can go overboard on porting and get even less USEABLE power that before porting. It is wise to do the valve job etc. but, I firmly believe that the $$$ spent in doing the full port job is better spent on the real power makers. Case in point, Nick (GSR) who posted on the first page has posted over 500 whp on a non ported head. I don't remember the exact #'s but it was hella big.
          Neon motor for applications over 250whp i'd strongly think about building the bottom end for reliability.
          • dubbsyD Offline
            dubbsyD Offline
            PSiedTSi wrote:
            ...theres a reason people only bore when they have to...
            not necessarily. 🙂
              If the older ones are what is being referred to, then you are right. I may be off a bit but I was thinking of the SRT4 engines.
                lilredcar wrote:
                a 2.4 out of a stratus/caravan pt crusier motor for a motor swap, just lookn to get the machine work done locally
                So your swapping a 2.4 PT Cruiser / Stratus in to a 1st Gen Neon?
                You could better use your money by building an RT motor (420a) and turboing that, you'll make much more power, and come out about the same in terms of the money you spend.
                Plus you could save a bundle and make more power by using already developed products besides hahn for the 420a... There's manifolds and everything by others now. You could start with the right size turbo (instead of a 16g) and make some real power...
                  aliengotpsi
                  Noob
                  Kevin Smith
                  Straightlinedetailing.com
                    Haha 3 pages of posts and not one mention of a machine shop to take his stuff to! Too bad Sturdevant's is gone or I would recommend them.
                      alright so i see that like i had originally thought that this site was a waste of time!! no need to reply cuz i wont be on here again , talk shit if you want noob you know nothing u havent done research whatever the story is say it if thats what helps you sleep at the end of the day rock on, btw iPSI2HI- said total rebuild, pertty sure the bottom end is in the motor? hummm u can read crazy things when you actually read the posts instead of catching the last thing and posting on JIM- the 2.4 into the neon puts out 30 more hp and is a fairly straight foward install nothing to complicated so how would the 420 bennefit me 2.4 50 lbs more turbo is a direct fit, a machine shop was that so hard? i didnt think so, ill ship it off else where to get the machine work done, peace 😄
                        Haha you have no clue, its ok though, you can talk shit about Fargostreet it aint a thang to me.
                        The funny thing is, you can go ahead and build your motor, port and polish and do whatever the hell your going to spend an arm and a leg on; and then you'll be claiming to make like 400hp with your Stage 10 Port Job, and then you go and race an almost stock DSM and you lose.
                        Its funny that you admit you know nothing about building motors, do you have any idea who the people on this site are your talking to?
                        But whatever, get outta hurr cause its a waste of your time being on here.
                        However, for the record, i guarntee that a built 420a w/ a large turbo on it would SMOKE a 2.4l (common are non turbo PT cruisers / stratus's fast????)
                        Whatever, btw your banned, becuase people like you tend to come back anyway
                        • ticklemedalyT Offline
                          ticklemedaly
                          From a professionals point of view, you are using the wrong motor for what you want to do. These motors, along with the 2.0 L neon motors are common for head and gasket problems, and overboaring the bottom end will create even more problems. If you really wanna do something along these lines, go with a SRT4 motor, they dont have the same problems....at least as many....and will be better off in the end for reliability. I know it may be expensive at first, but in the long run, itll be even more expensive with all the repairs you'll run into. Trust me, I have seen waaaaaaay too many of these motors with problems. Why run the risk of having more?
                          Ry
                          XBL G-tag: TickleMeDaly83
                          • naturalbornkellerN Offline
                            naturalbornkeller
                            lilredcar wrote:
                            a trubo setup is in the motors near future, hahun racecraft btw
                            "Trubo"? Man i love Trubos. They stay crunchy in milk!
                              Thatnx for the laugh Scott.
