  2. Local Shops and Businesses
  3. Straightline Detailing
  4. Need your DSM expertise
6 Posts 4 Posters 742 Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    Got John's GSX running, and it dosen't seem to have mechanical problems, but it does run funny. Seems like its running way too rich and the exhaust it thick and stinks like gas. Also it backfires a little. Does the cam sensor get the wrong reading if its 180* off, kinda like a V8 distribuor when you put it in 180 off?
    But other wise I got it all connected correctly and running but needs tuning, and I don't have enough knowledge to figure it out.
    Mike
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
      Mike
      CAS works both ways. Check for boost leaks, timing belt alignment, and firing order.
        aliengotpsi
        If you really want I may be able to come out there and take a look at it...
        does it rev all the way to 7k? with out much popping? I got a few ideas but would like to look at it first
        Kevin Smith
        Straightlinedetailing.com
          it backfires when it first starts sometime...
          it revs all the way to 7k without too much popping from what i remember yes.
            aliengotpsi
            are you 100% sure the timing belt isnt a clog off?
            Kevin Smith
              wa2fastcamaro
              I checked it like 15 times, damnit, it has to be right from what my manual says. If you would come look at it, and help get it running correctly I will give you a little $$ for your time.
              Mike
              Phone: 701-371-5615
