  4. LS Swap help
LS Swap help
6 Posts 5 Posters 221 Views
    I am trying to find a write up on an LS swap into a eg ex. I know u need motor mounts, ecu axles... etc. I SEARCHED HONDATECH, but I can't find an actual full write up on it. If anyone would like to do one for fargostreet, or if you knwo where one is on HT, LMK. Thanks
      just bolt the motor in and use an integra rear tranny mount not civic. Use axles from an integra,along with a computer for an integra ls or you could use a d15 computer if you dont have one. No wiring is needed.
      • darkelvisD Offline
        darkelvisD Offline
        darkelvis
        and done.
          Yeah, it is a bolt in affair.
            Agreed. I did this once and it all bolted in, and plugged in, and worked perfectly. Good luck searching on Honda Tech for that one. I posted about that same thing and all I got were replies saying "search search blah blah blah".
              That's why i posted on here, not on HT. Thanks guys... Will be picking a motor up with weekend more than likely.
