How fast will you be next summer?
stock my car runs 16.5 last summer pulled a 14.9 maaaaaaaybe juice and mid to low 13's
I'm going to make "Speedy Gonzales" look like "Regular Gonzales"!
My goals:
Gold Civic: 400+ hp high 10's low 11's
weight 1890 with 8 pt cage... also have more lexan to add..White Talon: 600+ hp + juice low 10's ??
weight:shooting for under 3000lbs keeping it mostly full interior
built auto with hi-stall
it made 485 hp on 23psi
also the goal is to have the fastest 4 cylinder around the area -
aliengotpsi wrote:
My goals:Gold Civic: 400+ hp high 10's low 11's
also the goal is to have the fastest 4 cylinder around the areanow these are something to look forward to.
i am so excited to get to the track.Monty
This is my goal.
89' crx si
stock b16 w/ arp head studs, new seals
holset hx35w on 10psi(street),14psi(track)
300-350hp goal
hope to hit high 11's low 12's on slicks -
I made my goal :icon_cheers:
STiSchucky wrote:
3's
qft -
hopefully break into the 11's...low 12's at least
integra_gsr98 wrote:
Faster than 11.0.
QFT as well.
If things go right ill swap a 3.8 series one Super Charged motor into my 92 grand am ill have 210+ horse in that compaired to 170ish that I have now. Plus I hope to have my 81 Monte Carlo finished it wont be fast but it will be a bit ballzy I have a edelbrock intake manafold and carb plus an ignition rebuild along with a repaint and restore of the interior.
Rice_Eater85 wrote:
If things go right ill swap a 3.8 series one Super Charged motor into my 92 grand am ill have 210+ horse in that compaired to 170ish that I have now. Plus I hope to have my 81 Monte Carlo finished it wont be fast but it will be a bit ballzy I have a edelbrock intake manafold and carb plus an ignition rebuild along with a repaint and restore of the interior.The 3300 doesn't have 170ish hp. It was rated at 160 but that thing is a pooch. Don't waste your time with the Series I, go right for the Series II. You'll be much happier.
