  4. Still boggin down...
129 Posts 21 Posters 5.0k Views
    wannabe;163683 wrote:
    an AFC isnt tuning properly....
    well go buy aem then...works fine for what he would need it for.
    • SlowicaS Offline
      SlowicaS Offline
      Slowica
      lol well i didn't really go into trying to check pulse rates unfortunatley the eclipse didn't have many sensors to get readings from. he did just get a new bov on but i think he was having the problems before that my thoughts were boost leak, maf, or maybe some bad / dirty injectors. i thought the wierd pulse rate may have shown something wrong with the injectors but ya, it was just a random guess. i guess he had it checked out by a mechanic who said there were no boost leaks so the other cause would be the maf. idk does anyone have a maf we could swap out with to see if thats the problem or would the scanner show the maf reading wrong through low voltage leves or anything?
        What all did you datalog?
        • SlowicaS Offline
          SlowicaS Offline
          Slowica
          lol cant really remember all of it. like i said barely had any time with it. there really wasn't very much to monitor or nothing helpfull at least. thats why im giving you things like the pulse widths. the eclipse wasn't even giving us rpms or the usual things you would want to monitor. when i had my celica hooked up it was everything you could ever want and more. eclipse its like battery voltage and random things like fuel tank preasure. hopefully we can take it out again tomorrow though and i can get more time to check things
            check the boost leaks your self. you can build a tool for like $5.
            why did he change the BOV?
              OWNED. and what SmitEvo says is true.
              but before you do that get your self a wideband and boost gauge.
                We have a MAF here to test. An O2 simulator simply shows the ECU that the cat is working correctly. It gives it a constant voltage reading like the second O2 would be doing.
                Was this done at full throttle? I know when I tested it myself, it seemed to drive fine after a few minutes. Definately check boost leaks.
                • SlowicaS Offline
                  SlowicaS Offline
                  Slowica
                  not my car lol he has has a cheep boost gauge though. anyways with the set up he has now i thought a boost leak would be very possible and why did he change the bov? to make it louder of course :icon_geek:
                    well, if there wasnt a leak before and you mess with stuff, then that could change that. and you have no idea if the mechanic he took it to could actually test it.
                    • SlowicaS Offline
                      SlowicaS Offline
                      Slowica
                      ya i was just going off of what he said, we will check it for boost leaks tomorrow.
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        91nbtsi
                        I would bet it has a somewhat large boost leak. It fits the symptoms perfectly.
                        [email protected] -- DSM
                        07 Mega Cab 5.9 CTD
                          Ding, ding, ding, johnny we got a winner.........why else would you put it in:icon_geek:
                            I believe that the ECU requires the O2 sensor to switch between .7 or whatever and 0 otherwise it will set a code
                            • blindsp1B Offline
                              blindsp1B Offline
                              blindsp1
                              with the test pipe the check engine light was on..then i cleared it about 3 months ago and it hasent come on since.....but i need to find a stock cat for cheap first...because the test pipe doesnt do anything anyway..
                              New Bike: 08 zx-6r FOR SALE
                              05 Yukon
                                or just get turbo back 3 inch exhaust.....
                                  The cat is not the root of your problems. From what Frank was saying you have your BOV duct taped on and you hacked up the stock plastic IC pipe to make it all fit up. For starters, fix that setup right and move on from there.
                                    not the downstream 02. the down stream 02 usually doesnt change its voltage much. it doesnt switch from 0-1 v like the upstream 02.
                                    • blindsp1B Offline
                                      blindsp1B Offline
                                      blindsp1
                                      im a poor white kid
                                      05 Yukon
                                      • blindsp1B Offline
                                        blindsp1B Offline
                                        blindsp1
                                        It wasent me who hacked it....beaner did...he said he did that to lacey's gst and said it worked...
                                        05 Yukon
                                          that is your problem
