  4. missing cam
missing cam
64 Posts 25 Posters 8.1k Views
  • StangerBanger96S Offline
    StangerBanger96
    MisterCMK;185753 wrote:
    NA 4.6 = faster than NA Honda
    NA 5.0 = faster than NA Honda
    Boosted 4.6 = faster than Boosted Honda
    Boosted 5.0 = faster than Boosted Honda
    Double Fixt for you Brandon 😄
      I got the accessory brackets bolted up and I started gasket matching the intake manifold. I have to go back to Home Depot to buy a different pipe for the damn EGR though. Maybe by this weekend it will run.
        thrash
        Ford engine bays are a complete nightmare. Those pics make me squeamish. I had a 85 Bronco II with the V6 and that thing sucked something fierce.
        Here's the engine bay of the 1991 BMW M5
        3.6 liters, 24 valves, 6 throttle butterflies, 310hp, ~270ft/lbs, 7000 rpm, DOHC, shim-over-bucket.
          StangerBanger96
          You can say that again.
            Hmm, I haven't had a problem with Ford engine bays. The Expedition with the 5.4 is a little on the tight side, as is the Modular SN95 'Stangs, but other than that they really aren't that bad. I have a 92 Explorer with the 4.0 V6 (basically the same as the truck you had) and there is LOTS of room in there.
              thrash
              The issue is about the rats nest of wires and hoses. Yeah, there's plenty of room in the mustang -- and its all filled with shit.
              Look how clean the layout of the M5 engine bay is. Everything is routed logically and cleanly. It's easy to tell what everything is and what it connects to.
                Meh, its the same way with the Fords too
                  StangerBanger96
                  Modular 4.6's and 5.4's are some of the biggest (dimensionally) engines Ford has ever made. They are way too big and way too underpowered.
                    I agree with that. Never said that they weren't.
                      StangerBanger96
                      Yeah I'm not sure why I hit the quote button on you there, meant to just say what I said and nothing else.
                      • dubbsyD Offline
                        dubbsyD Offline
                        dubbsy
                        Lots of room my ass..
                        not when you need to change plugs from the god damn wheel well on the passenger side....
                        I can actually SEE where the plug wires end on the Tahoe...
                        1995 Mustang
                        CAI, rimz, and springs.
                        • ParkerP Offline
                          ParkerP Offline
                          Parker
                          4.6 = Still a gay Ford
                          5.0 = Still a gay Ford
                          Fords new emblem
                          10 Jeep
                          10 F450
                          08 F250
                          05 F350
                          86 rx7
                          70 F100
                          63 Olds
                          > BlueSRT0483;244555 wrote:
                          > Trafik Jamz;260984 wrote:
                          > You are right Parker.
                          • D S ohMD Offline
                            D S ohMD Offline
                            D S ohM
                            :lol:
                            I wanna go fast!
                              I got the lower intake bolted on today and found out that I now need an intake spacer to run fox valve covers. fuck.
                              • 9 Offline
                                9 Offline
                                97lt1
                                You guys have never worked on a LT1 f-body. If you can work on one if these you can work on anything.
                                • dubbsyD Offline
                                  dubbsyD Offline
                                  dubbsy
                                  I think you'd say the same thing about a Supercoupe.
                                  I remember a buddy showing me pictures of the only real easy way to change spark plugs... the heads were on the work bench.
                                  1995 Mustang
                                    Word.
                                    Plug wires in an LT1 suck.
                                    On another note, I will be starting the car tonight.
                                      Parker;186095 wrote:
                                      Fords new emblem
                                      lol i changed the background on my managers computer to this^^ he drives a mustang also
                                        She fuckin runs!
                                        • GreenLanternG Offline
                                          GreenLantern
                                          Its about damn time you finished it....remember when i spit in your engine?
