  4. Rebuild kit?
Rebuild kit?
28 Posts 9 Posters 1.5k Views
    o i live for building d series for boost. how much power you wanna make?
    • CRX_CivicC Offline
      CRX_CivicC Offline
      CRX_Civic
      idk how much power, enough to make pontiacs look stupid but be able to withstand driving everyday. i could have mabey 1000$ by the time i need it........were did u see my car, cuz if it was when i had it on the hoist it was pretty nasty...
      Best P/W ratio...my h22a1 powered 2012 Harbor Freigh engine stand!:icon_thumleft:
        CRX_Civic;191540 wrote:
        Its for my engines class at MSCTC. i need to build, rebuild a engine. so i thought it would be a good idea to to the engine outta my civic. 206,xxx miles, smokes a little, leaks a little more, and it will be parkd for winter anyway. i would like to do a boost build but i need to start it within 2 weeks, so that leaves me know time to save some $. so yea, any ideas on cheap/good parts i can get in 2 weks
        seals are expensive, no way around that. But rings/bearings are cheap and someones gotta have em in town.
          ebay, get a full set of ACL rod, main, and thrust bearings for like 60-80 shipped. rings will come with some vitaras if he goes that route, they also sell a kit that come with pistons, head gasket, timing belt and some other crap too. get some TT rods, and a bottom end gasket kit for like 170 dollars from honda. these are just the prices off the top of my head, my prices are inaccurate cause i always get ill deals
          hone and notch that bitch and your ready to go.
          • inspector01I Offline
            inspector01
            Yea, you can build a D-series for boost for around $500 if you search for a bit, easily $700-800. Look around, ACL bearings off ebay, vitara pistons, eagle or TT rods, misc seals and gaskets, you are looking at $700 and a set up for 400 whp.
            PVC Squad Member #1
              Take spanish-rice and inspectors advice...they know how to build the d's for boost...if I ever went that route these are the guys i'd go to
                CRX_CivicC Offline
                CRX_Civic
                k so im lookin at pistons. most are 75mm, wich is the stock bore? some are 75.5mm. or other overbore sizes, should i get 75mm or should i get oversize, or...do i have to wait untill i measure my cylinder to see if it needs to be bored.
                  inspector01
                  Take apart the block and check out the cylinders to make sure they are ok and then get stock bore vitaras(75mm). Order them from FJT, he is a huge seller on all the forums like d-series, hmt, h-t. Then tuner toys or eagle rods, and then a gasket set from wherever you choose, ARP headstuds, and you are golden.
                  PVC Squad Member #1
