  4. Found this when I took my 4wheeler apart
6 Posts 6 Posters 465 Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    Well I have this polaris 300 4x4 4wheeler I have had for maybe 3 years now, The motor knocked some when I got it and Never got to fixing it, put maybe 200-300 miles on it with a knocking motor and finally last summer it locked up solid. It took until now that I gained enough motivation to take it apart, took about 3 hours to get the motor out and apart. I was expecting to find a broken rod or something but not a busted piston. I am not a expert on these motors but I say the whole thing is shot, the cranck case has a crack in it too, and the jug is scored to hell, like you were running sand in it. Guess I need to find a now motor.
    Also does anyone know of someone who can rebuild one of these motors reasonably?
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
      it doesnt look like you have the best luck with any internal combustion engine do ya?
      • DaveHD Offline
        DaveHD Offline
        DaveH
        Note to self: don't continue to drive vehicle with a knocking engine.
        :drunken_smilie:
        It's hard to tell, is it a 4-stroke or 2-stroke?
        If the cylinder is cast iron, most likely there is enough there to bore and put a oversize piston in. Broken cases aren't good, does it look like it broke from the stress of the engine locking up, or because something just hit it (piece of piston, etc)? If it was just hit, you should be able to weld it up and use it.
        DaveH
        '94 Supra- 7.77 @ 176mph
        • inspector01I Offline
          inspector01
          Your best bet will be to just find a motor out of a junked one or something, rebuilding would cost more and be more of a hassle than it is worth.
          PVC Squad Member #1
          • Afsil80A Offline
            Afsil80A Offline
            Afsil80
            Post of the year. And yes, this means 2008.
            -Peter
            1991 240SX
            • GarageAlchemistG Offline
              GarageAlchemist
              i cant believe my dad got that to run good like that, oh and if you case is cracked, rebuild isnt really an option...
              97 GTi, 03 KJ
