  4. Coyote rifle finished.
33 Posts 12 Posters 3.8k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    94NDTA
    Colts still makes flash supressors for there AR's.
    • harwood39H Offline
      harwood39H Offline
      harwood39
      i just added my optics to mine. nothing special. just a cheaper centerpoint/tactedge red/green dot sight. I have a rear BUIS on order from ranger joes along with a bayonet mounted pic rail, and pic rail mounted bi pod. more stuff will be coming later.
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        wtf do you have the optic up so high for?
        • bader3245B Offline
          bader3245B Offline
          bader3245
          co-witnessed
          2008 Ford F-150 FX4
          2006 Honda CRF250R
          2006 Honda CBR1000RR
            harwood39H Offline
            harwood39
            bader hit it on the head. its level with the irons, well once i get the rear one here it will be. Hopefully absolute co-witnessed which means the dot is in the same plain as the irons. if not it will be 1/3 co-witnessed which means the irons are in the 1/3 bottom of the optic. and it is forward so i can have the rear iron mounted.
            Im still debating on a fixed or flip up rear sight for it... I like the flip ups, but i love how ridged the fixed LMT sights are. And it wont matter as it ill be co-witnessed with the optic.
            This is the next optic i wanna try when i have the money and the rest off the gun is finished... http://www.burrisoptics.com/ar332.html
            Fargo, ND 58103
            701-429-3686
              thrash
              have you had a chance to try an EOTech HWS?
              I got a chance to play with one last week. Before actually looking through one mounted on a weapon, i didn't "get it". Now that I have, it makes sense. The target acquisition speed is really pretty impressive.. much better than even very high quality iron sights.
              For a CQB rifle, i think an EOTech stlye optic is hard to beat. The rear sight should be a folder that you'd want to keep down when the EOTech was functional. The optic should be on a quick-disconnect mount as well. LaRue tactical sells what is probably the top-shelf setup.
              I didn't like that turning the EOTech on/off was as finnicky as it was.. the model i used had the soft rubber buttons on the back of the unit.
              With a conventional optic, I might mount it further to the rear. The Troy BUIS I'm familiar with in the down position lets you get a normal small optic like that very close to the back of the rail, especially if the optic is on a QD mount.
                harwood39H Offline
                harwood39
                you dont need to have the optic on a quick mount if it is co-witnessed. you dont even need a flip up if it is done right. There is a lot of info concening this on ar15.com if it is co-witnessed properly and your optic dies, you look right through the optic with your irons... so there is no need to remove it.
                Also i like the eotech but i hate how you can not seal the lens/view window from the weather. that is why i like the burris/aimpoint/tactedge style better.
                Fargo, ND 58103
                701-429-3686
                  thrash
                  even if you get a glass failure or the seal is compromised and the interior fogs or something? co-witnessing still requires the glass to pass images relatively distortion free, right?
                  I figured that the BUIS use case was something that prevented the optic from passing an image at all.. did I misunderstand?
                    harwood39H Offline
                    harwood39
                    its mostly for if the battery dies, than you still have the BUIS to accurately aim the weapon. i guess if things go completely wrong i just turn 2 thumb screws and its off...
                    Fargo, ND 58103
                    701-429-3686
                      See the picture of my AR...
                      Larue/Troy Flipup Irons, Aimpoint Comp ML3 on Larue LT-150 mount, and Aimpoint 3x mag on Larue Pivot Mount.... Lower 1/3 cowitness with zero issues. The beauty of the dot is you can adjust it for POA/POI with your irons. If you haven't seen the magpul dynamics videos they have an excellent section on zeroing irons & optic on the first disc.
                        harwood39H Offline
                        harwood39
                        im jealous of your setup! lol. my original setup was goin to be an Eotech with 3x magnifier on the Eotech flip mount. but that is another grand away.... Also i may be putting this optic on another gun once i get my expensive setup for this rifle. I have a hi-point 995 9mm carbine that i picked up dirt cheap.
                        also, the magpul discs are awesome!
                        [ame]http://www.youtube.com/watch?v=Ye30b3TL5wI[/ame]
                        [ame]http://www.youtube.com/watch?v=NSJS3-O9xDo[/ame]
                        [ame]http://www.youtube.com/watch?v=segtXBwglj4[/ame]
                        [ame]http://www.youtube.com/watch?v=5IWKrt1e8Ek[/ame]
                        those guys are good at what they do.
                        Fargo, ND 58103
                        701-429-3686
                          I'd be willing to sell my Aimpoint setup if you're interested....
                            harwood39H Offline
                            harwood39
                            Im gonna wait on buying a better optic til i have the rest of the gun done. I wanna get my rail system, FUG, laser, Magpul ASAP, Magpul MS2 sling, rear BUIS, and light first. the red/green dot i have now is good enought. its 100% fog proof, water proof, and weather proof. So not in a hurry to upgrade yet.
                            Fargo, ND 58103
                            701-429-3686
