  4. Coyote rifle finished.
33 Posts 12 Posters 4.0k Views
  • bubbaB
    bubbaB
    SPANISH-RICE;266153 wrote:
    I want a sweet varmit gun 😞
    i'm sure we can hook u up with something...
    • SPANISH-RICES
      SPANISH-RICES
      LMK
      • bubbaB
        bubbaB
        SPANISH-RICE;266209 wrote:
        LMK
        tell me what u want for one... there's a lot of different choices..
        I suggest a Colt AR-15... we have 2 pre-1994 ban ones (they still have the flash suppressor) one was at like $1325, and idk bout the other, maybe a little less...
        • integra_gsr98I
          integra_gsr98I
          Pre-ban doesn't matter any more as you can buy anything current and let it have a flash hider....
          • integra_gsr98I
            integra_gsr98I
            However the pre-bans are worth coin to people in CA, CT, where they have statewide "assault rifle" bans.
            • bubbaB
              bubbaB
              but after the ban colt stopped making them with flash hiders... and as far as i know they never went back to making them with...
              • 94NDTA9
                94NDTA9
                Colts still makes flash supressors for there AR's.
                • harwood39H
                  harwood39H
                  harwood39
                  i just added my optics to mine. nothing special. just a cheaper centerpoint/tactedge red/green dot sight. I have a rear BUIS on order from ranger joes along with a bayonet mounted pic rail, and pic rail mounted bi pod. more stuff will be coming later.
                  2730 5th Ave S. Unit C
                  Fargo, ND 58103
                  701-429-3686
                  • integra_gsr98I
                    integra_gsr98I
                    wtf do you have the optic up so high for?
                    • bader3245B
                      bader3245B
                      bader3245
                      co-witnessed
                      2008 Ford F-150 FX4
                      2006 Honda CRF250R
                      2006 Honda CBR1000RR
                      • harwood39H
                        harwood39H
                        harwood39
                        bader hit it on the head. its level with the irons, well once i get the rear one here it will be. Hopefully absolute co-witnessed which means the dot is in the same plain as the irons. if not it will be 1/3 co-witnessed which means the irons are in the 1/3 bottom of the optic. and it is forward so i can have the rear iron mounted.
                        Im still debating on a fixed or flip up rear sight for it... I like the flip ups, but i love how ridged the fixed LMT sights are. And it wont matter as it ill be co-witnessed with the optic.
                        This is the next optic i wanna try when i have the money and the rest off the gun is finished... http://www.burrisoptics.com/ar332.html
                        Fargo, ND 58103
                        701-429-3686
                        • T
                          T
                          thrash
                          have you had a chance to try an EOTech HWS?
                          I got a chance to play with one last week. Before actually looking through one mounted on a weapon, i didn't "get it". Now that I have, it makes sense. The target acquisition speed is really pretty impressive.. much better than even very high quality iron sights.
                          For a CQB rifle, i think an EOTech stlye optic is hard to beat. The rear sight should be a folder that you'd want to keep down when the EOTech was functional. The optic should be on a quick-disconnect mount as well. LaRue tactical sells what is probably the top-shelf setup.
                          I didn't like that turning the EOTech on/off was as finnicky as it was.. the model i used had the soft rubber buttons on the back of the unit.
                          With a conventional optic, I might mount it further to the rear. The Troy BUIS I'm familiar with in the down position lets you get a normal small optic like that very close to the back of the rail, especially if the optic is on a QD mount.
                          • harwood39H
                            harwood39H
                            harwood39
                            you dont need to have the optic on a quick mount if it is co-witnessed. you dont even need a flip up if it is done right. There is a lot of info concening this on ar15.com if it is co-witnessed properly and your optic dies, you look right through the optic with your irons... so there is no need to remove it.
                            Also i like the eotech but i hate how you can not seal the lens/view window from the weather. that is why i like the burris/aimpoint/tactedge style better.
                            Fargo, ND 58103
                            701-429-3686
                            • T
                              T
                              thrash
                              even if you get a glass failure or the seal is compromised and the interior fogs or something? co-witnessing still requires the glass to pass images relatively distortion free, right?
                              I figured that the BUIS use case was something that prevented the optic from passing an image at all.. did I misunderstand?
                              • harwood39H
                                harwood39H
                                harwood39
                                its mostly for if the battery dies, than you still have the BUIS to accurately aim the weapon. i guess if things go completely wrong i just turn 2 thumb screws and its off...
                                Fargo, ND 58103
                                701-429-3686
                                • integra_gsr98I
                                  integra_gsr98I
                                  See the picture of my AR...
                                  Larue/Troy Flipup Irons, Aimpoint Comp ML3 on Larue LT-150 mount, and Aimpoint 3x mag on Larue Pivot Mount.... Lower 1/3 cowitness with zero issues. The beauty of the dot is you can adjust it for POA/POI with your irons. If you haven't seen the magpul dynamics videos they have an excellent section on zeroing irons & optic on the first disc.
                                  • harwood39H
                                    harwood39H
                                    harwood39
                                    im jealous of your setup! lol. my original setup was goin to be an Eotech with 3x magnifier on the Eotech flip mount. but that is another grand away.... Also i may be putting this optic on another gun once i get my expensive setup for this rifle. I have a hi-point 995 9mm carbine that i picked up dirt cheap.
                                    also, the magpul discs are awesome!
                                    [ame]http://www.youtube.com/watch?v=Ye30b3TL5wI[/ame]
                                    [ame]http://www.youtube.com/watch?v=NSJS3-O9xDo[/ame]
                                    [ame]http://www.youtube.com/watch?v=segtXBwglj4[/ame]
                                    [ame]http://www.youtube.com/watch?v=5IWKrt1e8Ek[/ame]
                                    those guys are good at what they do.
                                    Fargo, ND 58103
                                    701-429-3686
                                    • integra_gsr98I
                                      integra_gsr98I
                                      I'd be willing to sell my Aimpoint setup if you're interested....
                                      • harwood39H
                                        harwood39H
                                        harwood39
                                        Im gonna wait on buying a better optic til i have the rest of the gun done. I wanna get my rail system, FUG, laser, Magpul ASAP, Magpul MS2 sling, rear BUIS, and light first. the red/green dot i have now is good enought. its 100% fog proof, water proof, and weather proof. So not in a hurry to upgrade yet.
                                        Fargo, ND 58103
                                        701-429-3686
