  4. My new dd/beater project
53 Posts 20 Posters 4.9k Views
    dumb question, but I can't order those items through a Subaru dealer? reason I ask is I work at a dealer group, and get employee discounts on parts.
    • ColinC Offline
      ColinC Offline
      Colin
      you can order through a dealer, but only if you have the part number. a dealer can't search the part for you. meaning if you walked in and asked: "order me a lightweight bemper beam" the dealer would say: "i don't show that part".
      IF you said: " order part number 32527653464"
      they would say: "ok"
        Brandon, ever get the light figured out? I guarantee its the ground. If you cannot trace it, run a new one to the chassis.
        • M Offline
          M Offline
          me_john85
          looks pretty sweet, the RS front end is alot better
            No, stensland was looking at it, and said it must be a bad wire (grounding out but not enough to blow a fuse or something) between the relay and headlight, but i didnt have time to trace it yet.. it's getting the proper voltage and everything..
              makes sense. thanks.
                Brandon. I'm pretty sure it is a ground not supplying enough connection to allow full voltage. Tap a new chassis ground to each of the bulbs negative wire and verify this. It's quick and easy to do.
                  Bump... got fogs and stuff put in the bumper a while back, been too lazy to take pics...
                  However, i'm 90% sure this project is getting scrapped..
                  • 99civic9 Offline
                    99civic9 Offline
                    99civic
                    why is this???
                    2000 civic SiR - jdm sickness
                      99civic;300266 wrote:
                      why is this???
                      cause he is lazy! duh! 🙂
                        this
                          And cuz he NEVER finishes a project.
                            yep, putting it back to the way i bought it and selling it to the gf for cheap... crx is pending sale too... probably just buying a clean stock car...
