  4. Best gas in town?
Best gas in town?
33 Posts 9 Posters 8.6k Views
  • SheeranS Offline
    SheeranS Offline
    Sheeran
    WHat is your tester? I'd like to go test some of the 87 with up to 10% ethanol to see who has the least content so my turd box can get top mileage.
    BTW If you havn't noticed sams club is now 10% ethanol 87 and 10% ethanol 91.
    • legacy-user-351L Offline
      legacy-user-351
      Nothing fancy, I use a Quick Fuel Technology Echecker, not really intended to test E10...
      http://www.quickfueltechnology.com/specialty-parts/echecker---e85-fuel-test-tube.html
      Turkeylord
      '05 Legacy GT Wagon - 5MT Stage 4e
      '05 Yamaha Zuma - Stock
      • SheeranS Offline
        SheeranS Offline
        Sheeran
        wow thats pretty cheap. I see what your saying though, I will pick one up if I have a car that runs E-85 ever.
          legacy-user-351
          Here's what I had found before I bought the Echecker, it may help. Unfortunately, you'll have to math 😞
          http://iqlearningsystems.com/ethanol/downloads/E85test.pdf
          Turkeylord
            legacy-user-351
            Tested the e85 blend from the Petro Serve on 45th St and 9th Ave SW, 74% ethanol.
            Turkeylord
            • SheeranS Offline
              SheeranS Offline
              Sheeran
              O how I wish I were a cemistry major and i could do this in the lab with some spare time.
              Come to think about it your getting a lot or low ratings on your E-85 so I would assume the same for 10%. Though maybe there dumping more in to save cost and its really like 15% as thats what its going to jump up to in the future.
              • GrrG Offline
                GrrG Offline
                Grr
                testing E85 is pretty much a worthless endeavor.
                Read the SAE papers on it, there is virtually no difference in knock capability and power of E fuels from 50-85%. In fact you need to be OVER 85% to make any measureable difference with E98 only being marginally better than E85. Ive been using E85 for 7 years, and have never tested it once, never had any issues, and even ran the same tune on e85 and e50 with a VERY minor fueling adjustment, about 2%. In short its a GIANT waste of time
                Also E10 is certifiable up to 15% ethanol content with alot of it being 13-14% as an average
                2006 Trailblazer SS- my DD
                  legacy-user-351
                  I disagree, I've seen pretty large swings in my fuel trims switching blends. You could easily damage an engine switching from E70 to E85 and running lean before the trims sort it out. I make sure to stay in closed loop for a day or two before I run it hard.
                  Turkeylord
                  • GrrG Offline
                    GrrG Offline
                    Grr
                    Sorry dude but if you are pretty obsessed with your "tune", if your that close to the ragged edge you might want to back it off a tad. I run open loop speed density and never see more than .2 AFR difference ever. If the car runs drive it and dont waste so much time obsessing about tuning
                      legacy-user-351
                      Filled up Monday at Petro Serve on 2nd downtown - off the scale on my checker, but looks to be about e60. Starts great in the morning, but it's definitely pushed my fuel trims.
                      It's settled out a little better than this, but this was the low point...
                      I need to pull a log on it - if it looks clean I may run this all winter.
                      EDIT - Logs are clean. Idle trim is pegged at -15, but it seems to run fine.
                      Turkeylord
                        legacy-user-351
                        New tuner doesn't like Stop-N-Go's 91 octane, apparently. Still managed 6 more horsepowers and 11 more torques than my old e-tuner. 🙂
                        So, with the gas tune buttoned up, time to move on to e85.
                        Cenex @ 25th St & 23rd Ave - 68%
                        Don's @ 25th St & 52nd Ave - 95%
                        Dafuq. <sigh>
                        Turkeylord
                          Dafuq. <sigh>
                          How are you testing you e content? Maybe go back in a couple days and see if it is consistent.
                            legacy-user-351
                            Quickfuel Echecker.
                            legacy image legacy image
                            I went back the next day actually and tried a different pump - got e60. Went back to the pump from the night before and got e75. I called to ask about it, and they said that the e85 isn't blended at the pump, it's straight from the tank. I think the lower e content samples can be blamed on e10, 20 or 30 in the lines from a previous customer, but I can't explain that e95 sample. I measured it twice.
                            Turkeylord
