  4. Best gas in town?
Best gas in town?
33 Posts 9 Posters 9.0k Views
  • legacy-user-351L Offline
    legacy-user-351
    FWIW, I picked up 5 gallons of E85 at Petro Serve by I29 on Main today. Looks like 80% ethanol content according to my tester. I'll probably check a few more spots around town as I go.
      legacy-user-351
      Petro Serve/Tesoro on 2nd St: 70% ethanol
      Bjornson's on University: 82% ethanol
        Specialis
          Specialis
            legacy-user-351
            • SheeranS Offline
              SheeranS Offline
              Sheeran
              WHat is your tester? I'd like to go test some of the 87 with up to 10% ethanol to see who has the least content so my turd box can get top mileage.
              BTW If you havn't noticed sams club is now 10% ethanol 87 and 10% ethanol 91.
                legacy-user-351
                Nothing fancy, I use a Quick Fuel Technology Echecker, not really intended to test E10...
                http://www.quickfueltechnology.com/specialty-parts/echecker---e85-fuel-test-tube.html
                • SheeranS Offline
                  SheeranS Offline
                  Sheeran
                  wow thats pretty cheap. I see what your saying though, I will pick one up if I have a car that runs E-85 ever.
                    legacy-user-351
                    Here's what I had found before I bought the Echecker, it may help. Unfortunately, you'll have to math 😞
                    http://iqlearningsystems.com/ethanol/downloads/E85test.pdf
                      legacy-user-351
                      Tested the e85 blend from the Petro Serve on 45th St and 9th Ave SW, 74% ethanol.
                      • SheeranS Offline
                        SheeranS Offline
                        Sheeran
                        O how I wish I were a cemistry major and i could do this in the lab with some spare time.
                        Come to think about it your getting a lot or low ratings on your E-85 so I would assume the same for 10%. Though maybe there dumping more in to save cost and its really like 15% as thats what its going to jump up to in the future.
                          testing E85 is pretty much a worthless endeavor.
                          Read the SAE papers on it, there is virtually no difference in knock capability and power of E fuels from 50-85%. In fact you need to be OVER 85% to make any measureable difference with E98 only being marginally better than E85. Ive been using E85 for 7 years, and have never tested it once, never had any issues, and even ran the same tune on e85 and e50 with a VERY minor fueling adjustment, about 2%. In short its a GIANT waste of time
                          Also E10 is certifiable up to 15% ethanol content with alot of it being 13-14% as an average
                            legacy-user-351
                            I disagree, I've seen pretty large swings in my fuel trims switching blends. You could easily damage an engine switching from E70 to E85 and running lean before the trims sort it out. I make sure to stay in closed loop for a day or two before I run it hard.
                              Sorry dude but if you are pretty obsessed with your "tune", if your that close to the ragged edge you might want to back it off a tad. I run open loop speed density and never see more than .2 AFR difference ever. If the car runs drive it and dont waste so much time obsessing about tuning
                                legacy-user-351
                                Filled up Monday at Petro Serve on 2nd downtown - off the scale on my checker, but looks to be about e60. Starts great in the morning, but it's definitely pushed my fuel trims.
                                It's settled out a little better than this, but this was the low point...
                                I need to pull a log on it - if it looks clean I may run this all winter.
                                EDIT - Logs are clean. Idle trim is pegged at -15, but it seems to run fine.
                                  legacy-user-351
                                  New tuner doesn't like Stop-N-Go's 91 octane, apparently. Still managed 6 more horsepowers and 11 more torques than my old e-tuner. 🙂
                                  So, with the gas tune buttoned up, time to move on to e85.
                                  Cenex @ 25th St & 23rd Ave - 68%
                                  Don's @ 25th St & 52nd Ave - 95%
                                  Dafuq. <sigh>
                                    Dafuq. <sigh>
                                    How are you testing you e content? Maybe go back in a couple days and see if it is consistent.
                                      legacy-user-351
                                      Quickfuel Echecker.
                                      legacy image legacy image
                                      I went back the next day actually and tried a different pump - got e60. Went back to the pump from the night before and got e75. I called to ask about it, and they said that the e85 isn't blended at the pump, it's straight from the tank. I think the lower e content samples can be blamed on e10, 20 or 30 in the lines from a previous customer, but I can't explain that e95 sample. I measured it twice.
